NETGEAR WiFi 6 WAX620 Dual-band Access Point
Quicklinx: GCZSWS00 Mfr#: WAX620-100EUS
  • IEEE 802.11n
17 In Stock
£198.13 ex VAT
£237.75 inc VAT
The WAX620 is a high-performance Wi-Fi 6 access point, ideal for small and medium sized businesses. The access point is a dual-band 4x4 design delivering up to 3.6Gbps total Wi-Fi throughput, supported by a 2.5Gbps Power-over-Ethernet port, an industry leader of performance and cost effectiveness in its product class.
The WAX620 supports the next-generation Wi-Fi 6 smart phones, IoT devices, and notebook computers, delivering up to 40% more throughput to each individual device in the 5GHz band and 100% more throughput in the 2.4GHz band, compared to the previous generation equivalent model; provides 4x the client device connection, allowing businesses to serve more customers with better speed and less congestion.
The WAX620 is ideal in high-density client device environments such as schools, hotels, restaurants and conference centers, and provides enterprise-grade Wi-Fi network security. With Insight management, WAX620 works seamlessly with your current NETGEAR Insight managed switches, Wi-Fi access points and network storage, and is compatible with previous generation Wi-Fi devices (Wi-Fi 5 802.11ac for example) and Wi-Fi access points.
NETGEAR Insight WAX620 - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable - indoor
Europe
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum throughput (5 GHz): 2400 Mbps , Maximum throughput (2.4 GHz): 1200 Mbps
Maximum number of users: 256 , Concurrent users: 75 , SSIDs total: 8 , Streams: 8
Wall/ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE+
20.57 cm x 20.57 cm x 3.43 cm
783 g
5-year warranty
Radio access point
Ruggedized Design
Indoor
20.57 cm
20.57 cm
3.43 cm
783 g
Europe
Wireless
Line Coding Format
OFDM, OFDMA
Spread Spectrum Method
OFDM, OFDMA
Remote Management Protocol
RADIUS
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX3600
Status Indicators
Power, LAN, 2.4/5 GHz
VLAN support, auto-uplink (auto MDI/MDI-X), MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, bandwidth control, LLDP support, Captive Portal, 802.1x authentication, Beamforming+, Transmit Power Control (TPC), band steering, WDS bridge, Backhaul Technology, 4x4 MU-MIMO technology, WDS PTMP (Point to Multipoint), WDS PTP (Point to Point), WDS repeater mode, Target Wait Time (TWT), BSS Coloring, Guest Network, Neighbor AP detection, Block SSID Broadcast
Encryption Algorithm
SSL, TLS, PEAP, TTLS, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Authentication Method
RADIUS, Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
Internal
Internet of Things (IoT)
1 x 1/2.5GBase-T (PoE+) - RJ-45
PoE+
Software Included
NETGEAR Insight (1 year subscription)
Limited warranty - replacement - 5 years - response time: next business day , Technical support - 90 days
Type: Radio access point
Connectivity: Wireless
Speed: 3.6Gbps
Protocol: IEEE 802.11a
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: 802.11ax
Brand: NETGEAR
