N300 WiFi Range Extender boosts your existing WiFi home coverage and allows you to connect up to 4 wired devices like Smart TVs, gaming consoles to your wireless network. It works with any standard router or gateway and enables a better WiFi connection for laptops, home theater devices, smartphones and more.
Boost N300 WiFi -- Improve range and speed of your existing N300 WiFi network.
4 Fast Ethernet Ports -- Connect up to 4 wired devices like Blu-ray, players, game consoles, smart TVs or streaming players to your WiFi network.
It's Easy -- Easy installation using any web browser on laptops, PC's or tablets. No CD required.
- NETGEAR WN2000RPT Universal WiFi Range Extender - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Included Accessories
- Vertical stand
- 17.8 cm x 13 cm x 3.5 cm
- 0.68 kg
- 17.8 cm
- 13 cm
- 3.5 cm
- 0.68 kg
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz
- Status Indicators
- Status
- Wi-Fi Protected Setup (WPS), wireless bridge mode
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- 4 x 100Base-TX - RJ-45
- Vertical stand
- Power Device
- External power adapter
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
