NetGear ProSAFE WAC730 3 x 3 Dual Band Wireless AC Access Point
LIFETIME WARRANTY WITH NEXT BUSINESS DAY DELIVERY!
Quicklinx: BV0SWS00 Mfr#: WAC730-10000S
  • IEEE 802.11n
The NETGEAR WAC730 ProSAFE Wireless Access Point is a high-performance dual band 802.11ac AP supporting up to an aggregate throughput of 1.3 Gbps (450 Mbps for 2.4GHz and 1.3 Gbps 802.11ac for 5GHz) with standalone and Ensemble management for centralized group management of up to 10 APs. WAC730 Business AP operates in either standalone mode with an intuitive user interface or in Ensemble mode for centralized group management of up to 10 APs. It is perfectly positioned for customers demanding high throughput, ultra-superior performance, and extensive coverage deployment for Small and Medium Enterprises, K-12, and Hospitalities.
NETGEAR Business 3 x 3 Dual Band Wireless-AC Access Point WAC730 - radio access point - Wi-Fi 5
Radio access point
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1.75 Gbps , Maximum throughput (2.4 GHz): 450 Mbps , Maximum throughput (5 GHz): 1.3 Gbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
19.7 cm x 19.7 cm x 4 cm
726 g
NETGEAR lifetime warranty
Radio access point
19.7 cm
19.7 cm
4 cm
726 g
External
Wired
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, LAN, wireless, link/activity
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, LLDP support, 3T3R MIMO technology, 802.1x authentication, Transmit Power Control (TPC)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac
Aerial
Antenna
External detachable and internal
1 x console - RJ-45 , 1 x 1000Base-T (PoE) - RJ-45 , 3 x aerial - RP-SMA
1 x network cable
PoE
Limited warranty - lifetime
BV0S C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
