LG M38A 22" 1920x1080 5ms VGA LED Monitor
Quicklinx: C0MGWS00 Mfr#: 22M38A
Protect Your Eyes and View in Comfort
Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Preset Customized Options with just a Click
OnScreen Control and My Display Presets allow you to easily customize monitor settings with a few clicks of a mouse.
Customize Your Workspace for Multitasking
Screen Split divides the display for different tasks by resizing the windows on the screen. With PIP Mode you can work while watching a video in a window floating on the screen.
Offers Improved Color Vision to Color Weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
  • Protect your eyes and view in comfort
  • Preset customized options with just a click
  • Customize your workspace for multitasking
  • Offers improved color vision to color weakness
LG 22M38A - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
600:1
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
45% (CIE 1931)
Input Connectors
VGA
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
50.85 cm x 18.67 cm x 38.65 cm
2.4 kg
Plug and Play, DDC/CI
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
600:1
Colour Support
Colour Gamut
45% (CIE 1931)
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Hindi, Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Picture in picture, split screen, Picture Mode, On-screen Digital Controls, Flicker Safe, Reader Mode, Smart Energy Saving technology, My Display Preset, Color Weakness Mode, Mega DFC
50.85 cm x 18.67 cm x 38.65 cm - with stand
2.4 kg
VGA
Mechanical
VESA Mounting Interface
75 x 75 mm
Stand
1 x VGA cable
Input Voltage
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.85 cm - depth: 18.67 cm - height: 38.65 cm - weight: 2.4 kg , Without stand - width: 50.85 cm - depth: 5.68 cm - height: 31.57 cm - weight: 2.1 kg
C0MG StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
C0MG StarTech.com Articulating Monitor Arm In Stock £132.69
C0MG StarTech.com Dual Monitor Stand In Stock £91.00
C0MG StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
