LG 34" UltraWide FullHD IPS Monitor
Quicklinx: H3NWWS00 Mfr#: 34WQ680-W.AEK
Diagonal Size: 34in
Max Resolution: 2560 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
18 In Stock
£310.88 ex VAT
£373.05 inc VAT
Outstanding Color Accuracy and Wide Viewing Angle
LG IPS display supports a wide color spectrum, 99% of sRGB color gamut, and offers outstanding color and brightness with the support of VESA Display HDR™400.
Fully Use Your Desk
The compact design takes up very little desk surface and also contributes to easier installation.
Easy Connectivity
USB Type-C™ port allows from display and data transferring to connected device charging(up to 65W), enabling support for your laptop all at the same time over a single cable. It helps to boost efficiency and productivity by making a clutter-free workspace.
Incredible Speed to Victory
1ms MBR helps smooth gameplay, reducing blur and ghosting. Dynamic and fast-paced objects amidst all the action can give gamers a competitive edge.
  • Outstanding color accuracy and wide viewing angle
    LG IPS display supports a wide color spectrum, 99% of sRGB color gamut and offers outstanding color and brightness with the support of VESA Display HDR 400.
  • IPS display
    LG IPS monitor displays outstanding color accuracy with a wide viewing angle.
  • Fully use your desk
  • Easy connectivity
    USB Type-C port allows from display and data transferring to connected device charging, enabling support for your laptop all at the same time over a single cable. It helps to boost efficiency and productivity by making a clutter-free workspace.
  • Power delivery
    The image shows that the monitor and laptop computer are connected with the USB Type-C cable.
  • Protect your eyes with eye-care features
    Reader Mode creates a screen with a color temperature similar to paper and provides optimal condition for reading. Flicker Safe reduces invisible flickering on the screen, which helps reduce eye strain. It provides a comfortable working environment for a long time.
  • Reader Mode
  • Flicker Safe
  • Control with a few clicks
    You can customize the workspace by splitting the display or adjusting basic monitor options with just a few mouse clicks.
  • Immersive sound system
    This streamlined display features a slim bezel on three sides and no distractions from the dazzlingly precise, lifelike image while two 5W stereo speakers with MaxxAudio completes your immersive experience.
  • Incredible speed to victory
  • Dynamic Action Sync
    Reduces input lag with Dynamic Action Sync so it helps gamers catch critical moments in real-time.
  • Black stabilizer
    Gamers can avoid snipers hiding in the darkest places and quickly escape from the situations when the flash explodes.
LG UltraWide 34WQ680-W - LED monitor - 34" - HDR
LED-backlit LCD monitor - 34"
Energy Class
Class G
Adaptive-Sync Technology
AMD FreeSync
USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
WFHD 2560 x 1080 at 100 Hz
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10 / DisplayHDR 400
Response Time
5 ms (grey-to-grey), 1 ms (MBR)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt, extend, retract
Voltage
AC 100-240 V (50 - 60 Hz)
81.65 cm x 40.51 cm x 62.2 cm
9.9 kg
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
34"
AMD FreeSync
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
ErgoStand, Crosshair Display, Flicker Safe, Reader Mode, Motion Blur Reduction, Factory Calibration, MaxxAudio, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, Super Resolution+, 3-side virtually borderless display, HDR Effect, auto input switch, one click mount
81.65 cm x 40.51 cm x 62.2 cm - with stand
9.9 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DisplayPort 1.4 , HDMI , USB-C with Power Delivery (power up to 65W) , Headphones (mini-jack)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), C-clamp
1 x USB-C cable
Security Slot Type
Kensington security slot
Input Voltage
32 kWh/1000h
Power Consumption HDR (On mode)
42 kWh/1000h
Power Consumption (Typical)
35 Watt
Power Consumption (Max)
110 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dual Controller Software, LG On-Screen Control
Dimensions & Weight Details
With stand - width: 81.65 cm - depth: 40.51 cm - height: 62.2 cm - weight: 9.9 kg , Without stand - width: 81.65 cm - depth: 4.55 cm - height: 36.53 cm - weight: 6 kg
Shipping Width
91.4 cm
Shipping Depth
24.5 cm
Shipping Height
48.3 cm
Shipping Weight
12.9 kg
Limited warranty - parts and labour - 2 years
Diagonal Size: 34in
Response Time: 1ms
Interfaces: HDMI
Interfaces: USB-C
Brand: LG
