LG 45" UltraGear WQHD 240Hz Curved OLED Gaming Monitor
Quicklinx: HD1DWS00 Mfr#: 45GR95QE-B.AEK
Diagonal Size: 45in
Max Resolution: 3440 x 1440
Response Time: 0.03ms
Speakers: None
Interfaces: HDMI, USB, SPDIF
£1,332.50 ex VAT
£1,599.00 inc VAT
Born to Game
World's 1st 240Hz OLED Curved (800R) Gaming Monitor with 0.03ms (GtG) Response Time.
The Display
45" WQHD (3440x1440) Curved (800R) OLED
HDR10 / DCI-P3 98.5%
Anti-Glare / Low Reflection
The Speed
240Hz Refresh Rate
WQHD@240Hz from HDMI 2.1
The Technology
NVIDIA® G-SYNC® Compatible
AMD FreeSync™ Premium
45-inch 21:9 WQHD OLED
Panoramic Gaming View
Thanks to 21:9 WQHD OLED display with HDR10 and DCI-P3 98.5% (Typ.) wide color gamut, it can help gamers feel as if they were in the center of the game on the 45-inch large screen.
Self-lit OLED
SELF-LIT OLED Pixel provides a immersive gaming experience with its rich color expression and the contrast ratio as well as the fast response time.
  • Panoramic gaming view
  • SELF-LIT OLED
  • Show only your game
    Applying Anti-Glare & Low reflection technology can provide a better viewing experience anywhere by reducing screen distraction even in the surrounding lighting environment.
  • Lightning speed, fastest OLED on UltraGear
    LG's UltraGear monitor delivers the ultra-fast speed of 240 Hz refresh rate and 0.03 ms (GtG) response time on the OLED display.
  • Designed to immerse in gaming
    Delivers excellent uniformity with less brightness and color deviation as well as the same viewing angle with little distance from the center and outer edge of the display by applying 800R curvature.
  • Amplify your gaming output with OLED display
    45GR95QE is capable of up to 240 Hz refresh rate from HDMI. It means gamers can fully enjoy WQHD resolution and 240 Hz either by DisplayPort or HDMI.
  • Gamer-centric design
    Enhance your gaming experience with a Hexagon lighting and 4-side virtually borderless design. The adjustable base supports swivel, tilt, and height helps you play games more comfortably.
  • Plugin for immersive sound effect
    Enjoy your games while having voice chat by connecting easily with 4-pole Headphone out. Also, you can feel even more immersive with virtual 3D sound with DTS Headphone:X.
  • Play games and do more
    The 45GR95QE supports up to 2 PBP and PIP, allowing you to see the content coming from 2 inputs on one screen. It means you can run multiple games or tasks on one monitor at the same time.
LG UltraGear 45GR95QE-B - OLED monitor - curved - 45" - HDR
OLED monitor - 45"
Energy Class
Class E
Curved Screen
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible, AMD FreeSync Premium
USB 3.0 hub
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 240 Hz
Brightness
200 cd/m²
Contrast Ratio
1500000:1 (dynamic)
HDR Capable
HDR10
Response Time
0.03 ms (grey-to-grey)
Gaming
Colour Support
1.07 billion colours
Colour Gamut
98.5% DCI-P3 (CIE 1976)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, low reflection coating
Voltage
AC 100-240 V (50/60 Hz)
99.27 cm x 36.25 cm x 64.77 cm
10.9 kg
UL
1-year warranty
Display Type
OLED monitor / OLED
Energy Class
Class E
Energy Class (HDR)
Class F
Diagonal Size
45"
Viewable Size
44.5"
Curved Screen
Yes (800R)
Built-in Devices
USB 3.0 hub
Aspect Ratio
21:9
Native Resolution
Pixel Per Inch
84
Brightness
200 cd/m²
Contrast Ratio
1500000:1 (dynamic)
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Self-lit OLED
Crosshair Display, Reader Mode, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Color Weakness Mode, 4 Side Borderless Design, Overclock Refresh Rate, FPS Counter, HDR Effect, auto input switch, PIP support, HW calibration, Hexagon Lighting, user defined key, 2PBP, Gaming GUI, Variable refresh rate (VRR), OLED Care
99.27 cm x 36.25 cm x 64.77 cm - with stand
10.9 kg
SPDIF output , DisplayPort 1.4 , 2 x HDMI , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones (mini-jack)
Mechanical
VESA Mounting Interface
100 x 100 mm
DTS Headphone:X
Screwdriver, UltraGear remote control, stand cable holder
1 x HDMI cable , 1 x DisplayPort cable
UL
Input Voltage
39 kWh/1000h
Power Consumption HDR (On mode)
41 kWh/1000h
Power Consumption (Typical)
129 Watt
Power Consumption (Max)
160 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Dual Controller Software, LG On-Screen Control, LG Calibration Studio
Dimensions & Weight Details
With stand (highest position) - width: 99.27 cm - depth: 36.25 cm - height: 64.77 cm - weight: 10.9 kg , With stand (lowest position) - width: 99.27 cm - depth: 36.25 cm - height: 53.77 cm - weight: 10.9 kg , Without stand - width: 99.27 cm - depth: 21.8 cm - height: 45.7 cm - weight: 8.6 kg
Shipping Width
110 cm
Shipping Depth
31.7 cm
Shipping Height
55 cm
Shipping Weight
16 kg
Limited warranty - 1 year
Diagonal Size: 45in
Speakers: None
Interfaces: HDMI
Interfaces: USB
Interfaces: SPDIF
Brand: LG
Price Range Ex VAT: £1000 - £1500
