Brilliant LED backlighting display delivers crystal-clear images, true blacks and the most vivid, life-like colors on a slim screen. Fast response time of 5 ms allows the smooth viewing of action scenes, sports and video games with greater clarity and vivid quality. The consistent response time also allows you to watch videos or play games for a longer time while minimizing eye strain.
LED monitor
Brilliant LED backlighting display delivers crystal-clear images, true blacks and the most vivid, life-like colors on a slim screen. -
Fast response time
Fast response time of 5 ms allows the smooth viewing of action scenes, sports and video games with greater clarity and vivid quality. The consistent response time also allows you to watch videos or play games for a longer time while minimizing eye strain. -
Reader mode
Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long. -
Super energy saving
LG super energy saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight has improved from 25% to 30%. -
Flicker-safe
Dimming technology is applied to minimize the flicker level causing eye fatigue. With almost-zero flicker technology, you'll be able to watch longer, comfortably. -
Dual smart solution
This solution allows simple set up of dual monitor, dual taskbar and dual web.
- LG 22M35A-B - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- 50.9 cm x 21.5 cm x 41.1 cm
- 2.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Screen Coating
- Backlight Technology
- LED backlight
- Picture Mode, SUPER Energy Saving Technology, Auto Resolution, integrated cable management, Dual Smart Solution
- 50.9 cm x 21.5 cm x 41.1 cm - with stand
- 2.6 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -3/+20
- Power Supply
- Internal
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 50.9 cm - depth: 21.5 cm - height: 41.1 cm - weight: 2.6 kg , Without stand - width: 50.9 cm - depth: 9.8 cm - height: 31.6 cm - weight: 2.2 kg
Sustainability Information
- ENERGY STAR Certified
