Energy Saving
Enjoy the bright screen without any image loss. Save additional energy compared to conventional LED monitors. * Conserve energy by adjusting screen brightness.
Reader Mode
By reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for longer periods of time without straining your eyes.
Flicker Safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
Ergonomic Design
Our swivel tilting monitor has diverse swivel & tilt options ranged from 15° to 68° and from -5° to 35° respectively, to be perfectly adjusted for varied eye level and working conditions. Also, our pivot monitor can be changed to vertical anytime you want, keeping up with business situations like dealing with vertically long contents.
Built-in Power
Experience built-in adaptor which used to be assembled in the power cable. Feel how our built-in adaptor remarkably changed installation time to be a more convenient by omitting any struggles to pull it out from small size cable hole.
Versatile viewing angles
With a horizontal and vertical viewing angle of 178 degrees, the LG 24MB35PH offers a consistent and vibrant display from all perspectives, ensuring an optimal viewing experience for multiple users or when sharing content. -
Ergonomic design
This monitor provides extensive display position adjustments including height, pivot (rotation), swivel, and tilt, coupled with a 120 mm height adjustment range, allowing users to find the most comfortable and productive viewing position. -
Superior image quality
Featuring a dynamic contrast ratio of 5000000:1 and support for 16.7 million colors, the LG 24MB35PH delivers exceptionally crisp, bright, and vivid images, making it suitable for both professional and entertainment purposes. -
Energy efficient
Certified by ENERGY STAR, the LG 24MB35PH is designed with energy-saving technology, ensuring a lower energy consumption without compromising on performance, making it an eco-friendly addition to any workspace. -
Comprehensive connectivity
Equipped with HDMI, DVI-D, and VGA interfaces, this monitor offers versatile connectivity options, allowing easy setup and compatibility with a wide range of devices for both work and play.
- LG 24MB35PH - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.9 cm x 27.1 cm x 43.2 cm
- 5.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, CSA, UL, TUV GS, EN 61000-3-3, EN55024, TUV Ergo, DDC/CI, EN 61000-3-2:2006, EN 60950-1:2006, EN55022:2006 Class B
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 37 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- AH-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.274 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, gamma correction, phase, clock
- 4:3 in Wide, SUPER Energy Saving Technology, Dual Smart Solution
- Black
- 56.9 cm x 27.1 cm x 43.2 cm - with stand
- 5.1 kg
- VGA , DVI-D (HDCP) , HDMI , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 355
- Rotation Angle
- 90
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 25 W
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption (Typical)
- 31 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.9 cm - depth: 27.1 cm - height: 43.2 cm - weight: 5.1 kg , Without stand - width: 56.9 cm - depth: 6.3 cm - height: 34.2 cm - weight: 4.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.54 |
