Full HD
FULL HD resolution brings you magnificent picture quality through outstanding colour accuracy, visual contrast and sharpness
LED
Brilliant LED Backlighting display delivers crystal-clear images, true blacks and the most vivid, life-like colours on a slim screen
LED backlighting
LG's LED technology delivers amazing brightness, clarity and color detail. -
Full HD 1080p resolution
This stunning picture is the reason you wanted HD in the first place. With almost double the pixel resolution, Full HD 1080p gives it superior picture quality over standard HD. You'll see details and colors like never before. -
Super energy saving
For conventional LED monitors, power consumption may be reduced if luminance is reduced, but the display image turns dark. LG's super energy saving technology helps to reproduce images without losing brightness while saving on overall power consumption. -
Dual web
Dual web makes it easy to multitask. This feature optimizes the window size to automatically divide the screen to view multiple web pages at once.
- LG 24EN43VS-B - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 26 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-reflective
- Voltage
- AC 120/230 V
- Black
- 56.7 cm x 18.1 cm x 41.8 cm
- 3.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV GS, cUL, DDC/CI
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 38 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27675 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Response Time
- 5 ms
- Vertical Refresh Rate
- 56 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-reflective
- Backlight Technology
- LED backlight
- 4:3 in Wide, SUPER Energy Saving Technology, Auto Resolution
- Black
- 56.7 cm x 18.1 cm x 41.8 cm - with stand
- 3.6 kg
- VGA , DVI-D (HDCP) , HDMI , Headphones
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 26 W
- Power Consumption (Typical)
- 25 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.7 cm - depth: 18.1 cm - height: 41.8 cm - weight: 3.6 kg , Without stand - width: 56.7 cm - depth: 5.5 cm - height: 34.3 cm - weight: 3.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - on-site
