LG Electronics 23MP65HQ-P 23" 1920x1080 5ms VGA HDMI LED IPS Monitor
Quicklinx: 9D51WS00 Mfr#: 23MP65HQ-P
Cinema screen design delivers an incredibly immersive viewing experience. Minimized bezel won't let your view be obstructed by any frame around the screen. As LG IPS Monitor features consistency and less changes in color temperature, it realize a color impression identical to its original image. Experts have conducted color calibration tests at the production line for accurate color. LG IPS Monitor provides the most accurate and lifelike color for your advanced viewing pleasure.
  • Cinema screen
  • Lifelike color
  • Color calibrated
  • Reader mode
    Reducing blue light to protect your eyes, reader mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for long.
  • Flicker-safe
    The dimming technology is applied to minimize the flicker level causing eye fatigue. With almost-zero flicker technology, you'll be able to watch longer, comfortably.
  • Wide viewing angle
    LG IPS Monitor allows you to enjoy lifelike picture quality without any color shift whether you are standing or lying down.
  • Smooth color change
    Smooth color change allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
  • SUPER Energy Saving technology
    LG SUPER Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved from 25% to 30%.
  • SUPER+ Resolution technology
    SUPER+ Resolution technology helps to detect rough edges and blurring in contents when enlarged, offering improved quality with a better sense of high resolution.
LG 23MP65HQ-P - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
31 kWh
Power Consumption (On mode)
21 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
53.3 cm x 6.8 cm x 32.6 cm
2.6 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, EPA 6.0
Display Type
Energy Class
Class A
31 kWh
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, Picture Mode, SUPER Energy Saving Technology, SUPER Resolution, CINEMA Screen Design, Smooth Color Change, Lifelike Color, Dual Smart Solution
53.3 cm x 6.8 cm x 32.6 cm - without stand
2.6 kg
VGA , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
+5/+20
VESA Mounting Interface
75 x 75 mm
21 W
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
Without stand - width: 53.3 cm - depth: 6.8 cm - height: 32.6 cm - weight: 2.6 kg , With stand - width: 53.3 cm - depth: 18.8 cm - height: 42.6 cm - weight: 3 kg
