LG 27" UltraGear QHD IPS Gaming Monitor
Quicklinx: GQWNWS00 Mfr#: 27GN800-B
The pinnacle of gaming monitors. Complete your battle station with a premium LG UltraGear gaming monitor. Built for gamers, it delivers the latest hardware, specs, ergonomics, sleek design and sensory experience. With gaming-focused features like NVIDIA G-SYNC compatibility, 1ms GTG response times, pro-level customization and fast, vivid IPS panels, you're sure to gain an added edge.
  • IPS 1ms (GtG): designed for incredible speed
    With IPS 1ms comparable to TN speed, providing the minimized afterimage and a fast response time, you can enjoy a whole new gaming performance.
  • 144Hz refresh rate: fluid gaming motion
    An ultra-fast speed of 144 Hz allows gamers to see the next frame quickly and makes image to appear smoothly. The gamers can respond rapidly to opponents and aim at target easily.
  • HDR10 with sRGB 99% (Typ.): enjoy the latest HDR videos and games
    HDR10 elevates picture quality for a more dynamic visual immersion experience and enhanced color of HDR content. HDR10 is the digital HDR standard based on the sRGB 99% color gamut. A true difference in color and brightness.
  • Gain an edge with NVIDIA G-SYNC compatibility
    Officially verified NVIDIA G-SYNC compatibility. That translates to faster, smoother gaming that's been tested to reduce screen tearing, while minimizing stutter and input lag. Never miss a frame of the action as you clinch your victories with lag-free refresh rates.
  • Stylish design: an immersive experience that's all screen
    Beautiful and practically bezel-less. Stay in the game with a virtually borderless screen on three sides that keeps you immersed in every moment.
LG UltraGear 27GN800-B - LED monitor - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class G
Power Consumption (On mode)
31.3 W
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible, AMD FreeSync Premium
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Capable
HDR10
Response Time
1 ms (grey-to-grey)
Colour Support
1.073 billion colours (8-bit)
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 2H Hard Coating
Voltage
Matte black
61.42 cm x 22.48 cm x 45.42 cm
6 kg
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
HDR Format
HDR10
Colour Support
Colour Gamut
99% sRGB
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Crosshair Display, Flicker Safe, Reader Mode, SIX Axis Control, Mercury free, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Mega DFC, 99% sRGB colour gamut
Matte black
61.42 cm x 22.48 cm x 45.42 cm - with stand
6 kg
2 x HDMI , DisplayPort 1.4 , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 mm
Input Voltage
31.3 W
31.3 kWh/1000h
Power Consumption HDR (On mode)
47.9 kWh/1000h
Power Consumption (Typical)
48 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
LG On-Screen Control
Dimensions & Weight Details
With stand - width: 61.42 cm - depth: 22.48 cm - height: 45.42 cm - weight: 6 kg , Without stand - width: 61.42 cm - depth: 5.17 cm - height: 36.48 cm - weight: 5.6 kg
