Enjoy the supreme color and utmost speed simultaneously
Thanks to the UltraGear 27GP95R monitor, you can enjoy a whole new level of gaming immersion with UHD 4K high resolution, ultra-fast of speed. -
Sufficiently compatible with high gaming standard
LG 27GP95R is capable of processing UHD 4K video and variable refresh rate up to 120 Hz from HDMI. This allows gamers to enjoy immersive gaming experience. -
Support as one - UHD 4K, 10 bit and 160 Hz
Featuring VESA Display Stream Compression (DSC) technology, 27GP95R supports 4K high resolution, 144 Hz (O/C 160 Hz) hi-speed refresh rate with 1 ms (GtG) response time, HDR and G-SYNC compatible as well as covering 10 bit color by a single DisplayPort connection, and reducing visual loss. -
Vivid colors and sharp details
Nano IPS technology supports to express high-fidelity color for reproducing vivid scenes, while VESA DisplayHDR 600 delivers dynamic contrast, on the large UHD 4K screen. -
Designed for incredible speed
With IPS 1 ms comparable to TN Speed, minimizing reverse ghosting and providing fast response time, lets you to enjoy a whole new gaming performance. -
Fluid gaming motion
A ultra-fast speed of 144 Hz (Overclock 160 Hz) allows gamers to see the next frame quickly and makes image to appear smoothly. The gamers can response rapidly to opponents and aim at target easily. -
G-SYNC compatible validated by NVIDIA
27GP95R is a NVIDIA-tested and officially validated G-SYNC compatible monitor, minimizing screen tearing and stuttering for a smooth and fast gaming experience. -
Clearer, smoother and faster
With FreeSync Premium Pro technology, gamers can experience seamless, fluid movement in hi-resolution and fast-paced games. It virtually reduces screen tearing and stuttering. -
React faster to opponents
Reduce input lag with Dynamic Action Sync so it helps gamers catch critical moment in real-time. -
Attack first in dark
Black Stabilizer helps gamers to avoid snipers hiding in the darkest places and quickly escape situations when the flash explodes. -
Better aim
Target point is fixed in the center to enhance shooting accuracy.
- LG UltraGear 27GP95R-B - LED monitor - 4K - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class G
- Adaptive-Sync Technology
- VESA Adaptive-Sync, AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
- USB 3.0 hub
- Panel Type
- Nano IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 (DisplayPort(OC): 160 Hz, DisplayPort(DSC On): 144 Hz,DisplayPort(DSC Off): 120 Hz HDMI: 120 Hz)
- Pixel Pitch
- 0.1554 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Capable
- HDR10, HDR600 / DisplayHDR 600
- Response Time
- 1 ms (grey-to-grey)
- Gaming
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 98% DCI-P3 (CIE 1976)
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (highest position)
- 60.92 cm x 29.12 cm x 57.47 cm
- 7.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- Nano IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1
- HDR Format
- HDR10, HDR600
- HDR Certification
- DisplayHDR 600
- Colour Support
- Colour Gamut
- Response Time
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Crosshair Display, Flicker Safe, Reader Mode, Wide Colour Gamut, Smart Energy Saving technology, Color Calibrated, Black Stabilizer, DAS Mode (Dynamic Action Sync), Overclock Refresh Rate, Low Framerate Compensation (LFC), Sphere Lighting, 10-bit Colour Depth, FPS Counter, HDR Effect, HW calibration, user defined key, Gaming GUI, Variable refresh rate (VRR), VESA Display Stream Compression (DSC), 4-side virtually borderless display
- 60.92 cm x 29.12 cm x 57.47 cm - with stand (highest position)
- 7.9 kg
- 2 x HDMI , DisplayPort 1.4 (DSC (Display Stream Compression)) , USB 3.0 upstream , 2 x USB 3.0 downstream , Headphones (mini-jack)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Maxx Audio support
- Included Accessories
- Mouse holder
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB upstream cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption HDR (On mode)
- 86 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption (Max)
- 95 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Included Software
- True Color Pro, LG On-Screen Control, LG UltraGear Control Center
- Dimensions & Weight Details
- With stand (highest position) - width: 60.92 cm - depth: 29.12 cm - height: 57.47 cm - weight: 7.9 kg , With stand (lowest position) - width: 60.92 cm - depth: 29.12 cm - height: 46.47 cm - weight: 7.9 kg , Without stand - width: 60.92 cm - depth: 5.43 cm - height: 35.29 cm - weight: 5.7 kg
- Shipping Width
- 73.5 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 52.2 cm
- Shipping Weight
- 11.5 kg
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Parts and labour - 2 years
