LG 24" Full HD IPS Monitor
Quicklinx: H9J2WS00 Mfr#: 24MK43HP-B.AEK
Full HD IPS Display
High Definition with Accurate Colour
1080p Full HD resolution with IPS delivers brilliant images that pop with vibrant detail from any viewing angle.
AMD FreeSync™
Clearer, Smoother Image
AMD FreeSync™ Technology and a dynamic refresh rate
Dynamic Action Sync
React Faster to The Action
Dynamic Action Sync mode allows you to instantly react to your opponents and attack them without any display lag. It synchronizes your senses with real-time scenes in fast-paced games by minimizing input lag.e of 75Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
  • High definition with accurate color
  • Clearer, smoother image
    AMD FreeSync technology and a dynamic refresh rate of 75 Hz virtually eliminates screen tearing and stuttering to bring you seamless, fluid movement during high-res, fast-paced games.
  • React faster to the action
  • Enemies have nowhere to hide
    Black Stabilizer gives you full visual clarity, even in games where you spend a lot of time in the dark. It synchronizes and brightens the darkest areas, so that you can find enemies hiding in the shadows and shoot first.
  • Easier user interface
    OnScreen Control is simple and intuitive. You can customize your display options with a few simple clicks.
  • Convenient and flexible
    Mount the monitor to suit your work or entertainment set up.
LG 24MK43HP-B - LCD monitor - Full HD (1080p) - 23.8"
LCD monitor - 23.8"
Energy Class
Class E
Adaptive-Sync Technology
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (VGA: 60 Hz, HDMI: 75 Hz)
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Matte black
55.5 cm x 18.19 cm x 42.2 cm
3.1 kg
FCC Class B certified, VCCI, cUL, CCC, KC, ERP, TUV-TYPE
Display Type
LCD monitor / TFT active matrix
Energy Class
Class E
Diagonal Size
23.8"
AMD FreeSync
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
OSD Languages
Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Greek, Japanese, Chinese, Korean
Digital Fine Contrast ratio (DFC), Crosshair Display, Flicker Safe, Smart Energy Saving technology, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, Colour Temperature Selection, Super Resolution+, Black Level, gamma correction
Matte black
55.5 cm x 18.19 cm x 42.2 cm - with stand
3.1 kg
HDMI (HDCP 1.4) , VGA , Headphones
Mechanical
Tilt
Tilt Angle
-5/20
HDMI cable
Input Voltage
18 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
LG On-Screen Control
Dimensions & Weight Details
With stand - width: 55.5 cm - depth: 18.19 cm - height: 42.2 cm - weight: 3.1 kg , Without stand - width: 55 cm - depth: 3.84 cm - height: 33.09 cm - weight: 2.8 kg
Shipping Width
68.8 cm
Shipping Depth
39 cm
Shipping Height
12.4 cm
Shipping Weight
4.2 kg
