BenQ GL2760H 27" 1920 x 1080 5ms LED HDMI Glossy Black
Quicklinx: CBJYWS00 Mfr#: 9H.LC8LA.RBE
Whether you are catching up on the show on the Internet or viewing documents, the BenQ GL2760H LED monitor is the perfect choice for you in style! Featuring dynamic ratio of 12M:1, Flicker-free, and response time of 2 ms, this 27" 16:9 LED monitor delivers you the audiovisual enjoyment.
  • LED leads the way
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast and no light leakage, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • Flicker-free backlight for visual pleasure
    The GL2760H is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue.
  • 12M: 1 ultra high dynamic contrast for depth and definition
    The GL2760H comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the bright white to the darkest black, is perfectly rendered to deliver the clear, smooth picture performance during movies and video games.
  • Fast 2 ms GTG response time
    Fast response time of 2 ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of sluggish display.
  • Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and Eco - with the Eco mode especially designed to save power and money.
  • ecoFACTS label
    ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
BenQ GL2760H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
45 kWh
Power Consumption (On mode)
31 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
64.1 cm x 21.5 cm x 48.8 cm
5.4 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
45 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
2 ms (gray-to-gray)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye 3 Technology, Flicker Free technology, 72% NTSC colour gamut
Glossy black
5.4 kg
VGA , DVI , HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
31 W
Power Consumption (Typical)
28 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
CBJY C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
