BenQ GW2780 28" 1920x1080 5ms HDMI DisplayPort LED IPS Monitor
Quicklinx: D0LXWS00 Mfr#: 9H.LGELA.TBU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, VGA (HD-15), HDMI
16 In Stock
£174.79 ex VAT
£209.74 inc VAT
BenQ GW2780 27" frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care™ Technology with Low Blue Light Technology and Flicker-Free performance for extended viewing comfort, industry-leading Brightness Intelligence Technology delivers exquisite details in any ambient lighting environment.
  • Streamlined productivity & simplified lifestyle
    Designed for beautiful simplicity, BenQ GW2780 frameless monitor combines ultra slim bezels with hidden cable management. Complementing BenQ exclusive Eye-Care technology with Low Blue Light and Flicker-Free performance for extended viewing comfort, Brightness Intelligence technology delivers exquisite details in any ambient lighting environment. With the ideal combination of LED and IPS technologies, GW2780 delivers an amazing level of visual enjoyment with truly authentic colors, deeper blacks, higher contrast, and sharper details.
  • Ultra slim bezel design
    GW2780 offers a visually spectacular edge-to-edge panel with ultra slim bezels and elegant profile that beautifully complements any modern decor.
  • Cable management system
    Invisible cable management system neatly hides all wires inside the monitor stand for a clean look.
  • IPS wide viewing angle technology
    IPS technology ensures accurate color and image reproduction from any angle. Expansive 178° horizontal and vertical viewing angles ensure uniform viewing for multiple people in the room.
  • Brightness Intelligence technology
    Brightness Intelligence technology optimizes display performance for work and play, protecting your vision with superb image quality.
  • Low Blue Light
    Proprietary BenQ Low Blue Light technology filters out hazardous blue light, effectively reducing eye fatigue and irritation.
  • Flicker-Free technology
    Exclusive BenQ Flicker-Free technology eliminates the harmful flicker of traditional LCDs to prevent fatigue and vision damage.
BenQ GW2780 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class E
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
19.2 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 8 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Voltage
61.2 cm x 18.3 cm x 46.3 cm
4.85 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
TUV Bauart, DisplayPort 1.2, HDCP 1.4
Display Type
Energy Class
Class E
34 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Hungarian, Czech, Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Chinese, Korean
Cable management cover, Advanced Motion Accelerator (AMA) technology, Low Blue Light Mode, Flicker Free technology, Ultra Slim Design Bezel, Bright Intelligence (B.I.), Eye-Care Technology
61.2 cm x 18.3 cm x 46.3 cm - with stand
4.85 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA , DisplayPort , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
19.2 W
19.2 kWh/1000h
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 18.3 cm - height: 46.3 cm - weight: 4.85 kg , Without stand - width: 61.2 cm - depth: 5 cm - height: 38.1 cm
Shipping Weight
6.5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
Diagonal Size: 27in
Response Time: 5ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: BenQ
