Designed to meet the rising demands for large-sized viewing and stunning definition, the PD3200Q boasts a 32"W 2K display built with BenQ's VA panel technology to provide higher contrast and deeper blacks.
- BenQ PD3200Q - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class G
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 41.7 W
- KVM Switch, USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI-D, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), tilt
- Voltage
- AC 90 - 264 V (47 - 63 Hz)
- Black
- 74 cm x 21.3 cm x 49 cm
- 12.5 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Energy Class
- Class G
- 57 kWh
- Diagonal Size
- 32"
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440
- Pixel Pitch
- 0.276 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Eco-Mode, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Dual View, animation mode, OSD controller
- Black
- 74 cm x 21.3 cm x 49 cm - with stand
- 12.5 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DVI-D , DisplayPort , Headphones , Audio line-in , 4 x USB 3.0 , HDMI
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 41.7 W
- Power Consumption SDR (On mode)
- 41.7 kWh/1000h
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- OS Required
- Apple MacOS, Windows 8 / 10
- Dimensions & Weight Details
- With stand - width: 74 cm - depth: 21.3 cm - height: 49 cm - weight: 12.5 kg , Without stand - width: 74 cm - depth: 6.6 cm - height: 43.6 cm
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 90%
