Acer K272HL 27'' 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: BQRYWS00 Mfr#: UM.HW3EE.009
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
  • Full HD LED monitor
  • ComfyView
    Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
  • Acer Adaptive Contrast Management
    Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by frame, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
Acer K272HL - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
26.1 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Voltage
64 cm x 24.9 cm x 46.2 cm
5 kg
Microsoft Certification
Compatible with Windows 7
MPR II
Display Type
Energy Class
Class F
43 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
64 cm x 24.9 cm x 46.2 cm - with stand
5 kg
DVI , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
1 x VGA cable
MPR II
Input Voltage
26.1 W
26.1 kWh/1000h
Power Consumption (Typical)
28.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
With stand - width: 64 cm - depth: 24.9 cm - height: 46.2 cm - weight: 5 kg , Without stand - width: 64 cm - depth: 6.2 cm - height: 38.1 cm - weight: 4.77 kg
BQRY C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
