Acer B277Ubmiipprzx 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: G0GNWS00 Mfr#: UM.HB7EE.030
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, Mini DisplayPort, HDMI
£252.57 ex VAT
£303.08 inc VAT
Planted upon its sturdy, robust stand, feel free to turn, pivot and swivel the display to whatever the occasion calls for. In the professional world, accuracy is everything. Utilize color-enhancing and eyecare technologies for pinpoint precision. The near bezel-less design creates a more seamless look, allowing you to see more of what matters most: the screen. The built-in speaker system lets you enjoy powerful sound without the need for a separate set up.
  • Essential ergonomics
  • Infused with color
  • ZeroFrame design
  • Built-in speaker
Acer B277U bmiipprzx - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
26 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
61.4 cm x 20.8 cm x 40.1 cm
7.77 kg
Environmental Standards
TCO Certified Displays 8 EPEAT Bronze
DisplayPort 1.2
Display Type
Energy Class
Class F
52 kWh
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
93
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 120 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ErgoStand, Acer Adaptive Contrast Management (ACM), ComfyView, Flicker-Less technology, Low Dimming technology, Super Sharpness technology, Adaptive-Sync technology, Acer VisionCare, Acer BluelightShield technology, 6-Axis Color Adjustments, Acer ColorPlus technology, Acer Display Widget, 3-sided bezeless
61.4 cm x 20.8 cm x 40.1 cm - with stand
7.77 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , DisplayPort 1.2 , Mini DisplayPort , Audio line-out , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
180
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable , 1 x SuperSpeed USB cable
DisplayPort 1.2
Security Slot Type
Kensington security slot
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Shipping Weight
10.81 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Bronze
Diagonal Size: 27in
Response Time: 4ms
Interfaces: Mini DisplayPort
Interfaces: HDMI
Brand: Acer
