Acer B248Ybemiqprcuzx 23.8" 1920x1080 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: G9J2WS00 Mfr#: UM.QB8EE.002
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, USB-C, HDMI
More than 50 In Stock
£239.42 ex VAT
£287.30 inc VAT
The Acer B248Y is an ergonomic monitor that has been designed around cushioning various pain points that come up in a day's work. TÜV/Eyesafe certified, the monitor includes a number of features that aim to reduce eye-strain, such as Acer LightSense and Acer ColorSense, which automatically adjust screen brightness and color temperature to match the environment. The monitor's FHD (1980 x 1080) IPS display sits on an Ergostand, a flexible stand that makes it easy to adjust the display's height, swivel or tilt, or even rotate 90 degrees into portrait mode.
Easy on the eyes, the B248Y can also make the most of any desk. Its built-in docking station turns the monitor into a workspace in its own right, serving to remove clutter and making use of RJ45 and USB Type-C 100W PD ports which simplify the process of moving work from office to office, or back home. Multiple monitors can be daisy-chained together, for those who need more screen real estate, and an adjustable FHD webcam that supports Windows Hello enables users to rotate the camera's feed until they find the perfect angle, or physically close it to avoid accidental sharing during a meeting.
  • Superior Visuals
    Enjoy a bezel-less view from the ZeroFrame design and superior visuals with 72% NTSC and Delta E<2 color accuracy.
  • Acer VisionCare 3.0
    Acer VisionCare 3.0 technology reduces eye strain by detecting the amount of light in the environment and automatically adjusting to provide the most comfortable viewing experience possible.
  • Convenient Conferencing
    The adjustable webcam paired with Windows Hello not only makes it easier to sign in, but gives you the flexibility to find the best and most comfortable angle during online meetings.
  • Tidying Up
    Reduce unnecessary desk clutter by using the USB Type-C and RJ45 ports located directly on the monitor itself.
  • Daisy Chain Multiple Displays
    Easily link screens together with a single connection with daisy chain functionality.
  • Adaptive-Sync
    With Adaptive-Sync, the monitor's framerate is synced with that of the graphics card, which eliminates screen tearing and delivers ultra-smooth video playback.
Acer B248Y bemiqprcuzx - B8 Series - LED monitor - Full HD (1080p) - 23.8" - HDR
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
17 W
Adaptive-Sync Technology
VESA Adaptive-Sync
Microphone, USB 3.0 hub, FHD camera
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Environmental Standards
TCO Certified Displays 8, TCO Certified Displays 9 EPEAT Bronze
DisplayPort 1.4, TUV Eyesafe Display Certification
Display Type
Energy Class
Class E
Energy Class (HDR)
Class F
Diagonal Size
23.8"
VESA Adaptive-Sync
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
HDR Format
HDR10
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, Zero Frame, Acer VisionCare, 3-sided bezeless, Delta E<1 calibration, Eyesafe technology
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DisplayPort 1.4 , DisplayPort output , USB-C with Power Delivery (power up to 100W) , Network (RJ-45) , Audio line-out , 2 x USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x HDMI cable , 1 x USB-C cable , 1 x SuperSpeed USB cable
Input Voltage
17 W
17 kWh/1000h
Power Consumption HDR (On mode)
20 kWh/1000h
Included Software
Acer Smart Console
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Bronze
Response Time: 4ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Acer
