Easily Expanding Home Wireless Coverage with Dual-Band Technology
ZyXEL's WRE6505 Wireless AC750 Range Extender provides wireless coverage throughout your home. Just plug the unit into a power outlet, and LED lights will indicate signal strength so you can place it on the optimum spot. The one-click Wi-Fi Protected Setup (WPS) setup simplified installation while a built-in Ethernet port provides instant network connection to multiple wired devices.
Easy Wireless Extension - Expand wireless coverage easily
The ZyXEL WRE6505 extends and broadens your 802.11 a/b/g/n/ac wireless network coverage by eliminating dead spots for whole-home coverage. It allows you to enjoy the fastest video streaming, gaming and Web browsing on tablets, laptops or smartphones anywhere in the house, and it's backward compatible with all your current 802.11 a/b/g/n routers and access points.
Extender/AP Switch Mode
Dual-band technology with "Speed/Range Boost" for advanced performance
The "Speed Boost" and "Range Boost" modes of the ZyXEL WRE6505 help establishing interference-free, optimal throughput as well as coverage. Choose the "Range Boost" mode for maximum wireless coverage or "Speed Boost" mode to prioritize speed over coverage.
Dual-Band
Compliant with 802.11ac with dual-band concurrent wireless
The ZyXEL WRE6505 is backward compatible with all your current 802.11 a/b/g/n routers and access points; and it helps to transmit signals using the less-crowded 5 GHz band for smooth streaming and low latency for games.
Compact wall-mount design for convenient deployment
The ZyXEL WRE6505 has been designed to allow flexible deployment, giving you the best wireless coverage and performance while eliminating the unsightly wires. Additionally, the device offers LED of three colors (red-good/amber-better/green-best) to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy your high-speed wireless network throughout your home in minutes.
The ZyXEL WRE6505 extends and broadens your 802.11 a/b/g/n/ac wireless network coverage by eliminating dead spots for whole-home coverage. It allows you to enjoy the fastest video streaming, gaming and Web browsing on tablets, laptops or smartphones anywhere in the house, and it's backward compatible with all your current 802.11 a/b/g/n routers and access points. -
The "Speed Boost" and "Range Boost" modes of the ZyXEL WRE6505 help establishing interference-free, optimal throughput as well as coverage. Choose the "Range Boost" mode for maximum wireless coverage or "Speed Boost" mode to prioritize speed over coverage. -
The ZyXEL WRE6505 is backward compatible with all your current 802.11 a/b/g/n routers and access points; and it helps to transmit signals using the less-crowded 5 GHz band for smooth streaming and low latency for games. -
The ZyXEL WRE6505 has been designed to allow flexible deployment, giving you the best wireless coverage and performance while eliminating the unsightly wires. Additionally, the device offers LED to indicate the signal strength for optimal Wi-Fi coverage. You can install it at the location with the strongest wireless signal to extend wireless coverage and enjoy your high-speed wireless network throughout your home in minutes.
- Zyxel WRE6505 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power
- AC 120/230 V (50/60 Hz)
- 4.65 cm x 6.23 cm x 9.09 cm
- 98 g
- 4.65 cm
- 6.23 cm
- 9.09 cm
- 98 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 450 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, WLAN, LAN, WPS
- Auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Access Point operational mode, firmware upgradable, Wi-Fi Multimedia (WMM) support, Auto Channel Select (ACS), Wi-Fi Protected Setup (WPS)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
- 1 x 100Base-TX - RJ-45
- Cables Included
- 1 x network cable
- FCC, LVD
- Power Device
- Internal power supply
- Voltage Required
- 3 Watt
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
