2.5X more capacity with the new 6GHz band
Delivering up to 5.4Gbps speed, the Zyxel NWA220AXE-6E is fully equipped with the next-gen WiFi 6E technology for ultra-fast speeds and low-latency connections.
Flexible BandFlex radio design
The Zyxel NWA220AX-6E is the dual-radio access point with a BandFlex radio design that can support either 5GHz or 6GHz by configuration, making it the most economical choice to fit into your existing 5GHz coverage as well as futureproofing the use of 6GHz.
Zyxel 6E Boost
The high-gain 4x4 streams in 6GHz design helps increase the maximum gains in transmit beamforming and receive MIMO to extend range and maximize the performance of the new band.
NWA220AX-6E for High-density WiFi
WiFi 6E, the new 6 GHz band, presents a solution to quenching the thirst for today’s hunger for more bandwidth. The NWA220AX-6E’s BandFlex radio design allows the AP to support either 5GHz or 6GHz band by configuration, making it the most economical choice to fit into your existing 5GHz coverage, as well as futureproofing the use of 6Ghz.
- Zyxel NWA220AX-6E - radio access point - Wi-Fi 6 - cloud-managed
- Radio access point
- Form Factor
- External
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, IEEE 802.11ax (Wi-Fi 6)
- Frequency Band
- 2.4 GHz, 5 GHz, 6 GHz
- Performance
- Maximum data rate (2.4 GHz): 575 Mbps , Maximum data rate (5 GHz): 4800 Mbps , Maximum data rate (6 GHz): 4800 Mbps
- Included Accessories
- Mounting screws, mounting plate
- Power Over Ethernet (PoE) Supported
- PoE+
- Power
- DC 12 V
- 18 cm x 18 cm x 4.2 cm
- 650 g
- 18 cm
- 18 cm
- 4.2 cm
- 650 g
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- IPv6
- Remote Management Protocol
- SNMP
- Cloud-Managed
- Frequency Band
- Performance
- Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Advanced Cellular Coexistence (ACC), cloud managed, ZyXEL wireless optimizer (ZWO), MU-MIMO technology, Unscheduled Automatic Power Save Delivery (U-APSD), band steering, Fast Roaming, Dynamic Channel Selection (DCS), ZON Utility, L2-isolation, rogue AP detection
- Encryption Algorithm
- WPA, WPA2, WPA2-PSK, WEP, WPA3, WPA3-Enterprise
- Authentication Method
- RADIUS, Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 2, IEEE 802.11ax
Aerial
- Antenna
- Internal
- Gain Level
- 6 dBi
- 1 x 1/2.5GBase-T (uplink, PoE+) - RJ-45 , 1 x 1000Base-T - RJ-45
- MTBF
- 711,333 hour(s)
- EN55022, EN55024, FCC Part 15 B, FCC Part 15 C, FCC Part 15 E, BSMI CNS 13438, EN 60601-1-2, BSMI CNS 14336-1, EN 301 489-1, LP0002, ETSI EN 300 328, EN 301 893, IEEE 802.3af, IEEE 802.3at, EN 301 489-17, IEEE 802.3bt, EN 62368, EN 303 687
- PoE+
- Power Device
- External power adapter
- Voltage Required
- DC 12 V
- 21 Watt
- Shipping Width
- 19.7 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 6 cm
- Shipping Weight
- 780 g
- 0 °C
- 50 °C
- 10 - 95% (non-condensing)
