The Wireless N Gaming Adapter (TEW-647GA) connects your favorite Ethernet-ready gaming console to a lag-free wireless N network. No need to locate your gaming station near an Internet connection - cut your cables and start winning with high-performance wireless N. Setup is quick and simple, with no drivers to install. It works with Nintendo Wii, Xbox, Xbox 360 and PlayStation 2 and 3. Connect multiple gaming consoles wirelessly and play head-to-head or challenge others over the Internet in multiplayer mode.
The wireless encryption ensures wireless security. Advanced Multiple Input Multiple Output (MIMO) antenna technology reduces wireless dead spots. Wireless Protected Setup (WPS) lets you integrate other WPS devices into your secured network quickly.
- TRENDnet TEW 647GA Wireless N Gaming Adapter - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- OS Required
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- 10 cm x 7 cm x 2 cm
- 80 g
- 3-year warranty
- 10 cm
- 7 cm
- 2 cm
- 80 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz
- Max Range Indoors
- 50 m
- Max Range Open Space
- 100 m
- Status Indicators
- Port status, power, status
- Hardware encryption, MIMO technology, Wi-Fi Protected Setup (WPS)
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Directivity
- Omni-directional
- 1 x 100Base-TX - RJ-45
- Cables Included
- 1 x network cable - 60 cm
- FCC, RoHS
- ENERGY STAR Certified
- Power Device
- External power adapter
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95%
