TP LINK EAP660 HD AX3600 Wireless Dual Band Multi-Gigabit Ceiling Mount Access Point
Quicklinx: G6WMWS00 Mfr#: EAP660 HD
Type: Radio access point
Connectivity: Wireless
Speed: 2402Mbps
Protocol: IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n + 2 more
Compatibility: PC
  • IEEE 802.11n
31 In Stock
£190.78 ex VAT
£228.93 inc VAT
The Omada Wi-Fi 6 Access Point features the latest 802.11ax technologies like 1024 QAM and Long OFDM Symbol, which allows the EAP to boost overall speeds up to 3550 Mbps (2402 Mbps on a 5 GHz band and 1148 Mbps on a 2.4 GHz band). With 8 spatial streams, multi-user throughput is incredibly increased to drive more applications.
Armed with a 2.5 Gigabit Ethernet Port, the EAP660 HD delivers exceptional multi-gigabit performance to support the insatiable demand for better and faster Wi-Fi. Compatibility with standard 802.3at PoE+ is ideal for flexible deployment.
  • Ultra-fast Wi-Fi 6 speeds
    Simultaneous 1148 Mbps on 2.4 GHz and 2402 Mbps on 5 GHz totals 3550 Mbps Wi-Fi speeds.
  • High-density connectivity
    4x increased capacity to connect more devices simultaneously.
  • Integrated into Omada SDN
    Zero-Touch Provisioning (ZTP)ยง, Centralized Cloud Management, and Intelligent Monitoring.
  • Centralized management
    Cloud access and Omada app for ultra-convenience and easy management.
  • 2.5G port
    A 2.5 Gbps Ethernet port boosts total internet throughput.
  • Seamless roaming
    Even video streams and voice calls are unaffected as users move between locations.
  • PoE+ support
    Supports Power over Ethernet (802.3at) for convenient deployment and installation.
  • Secure Guest Network
    Along with multiple authentication options (SMS/Facebook Wi-Fi/ Voucher, etc.) and abundant wireless security technologies.
TP-Link EAP660 HD AX3600 Wireless Dual Band Multi-Gigabit Ceiling Mount Access Point - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 16
Wall/ceiling mounting kit
Linux, Microsoft Windows XP / Vista / 7 / 8 / 10
Power Over Ethernet (PoE) Supported
PoE
24.3 cm x 24.3 cm x 6.4 cm
Radio access point
24.3 cm
24.3 cm
6.4 cm
Wireless
Line Coding Format
OFDM, 1024 QAM, OFDMA
Spread Spectrum Method
OFDMA
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AX3600
VLAN support, E-mail alert, MAC address filtering, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), SSH support, rogue access point detection, Captive Portal, Transmit Power Control (TPC), MU-MIMO technology, beamforming technology, band steering, rate limit, Wireless Scheduler, seamless roaming, Airtime Fairness, schedule reboot, load balance network mode
Encryption Algorithm
WPA-Enterprise, WPA2-Enterprise, WEP, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, WPA-Personal
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.11ac, IEEE 802.11ax
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 2.5 GBase-T (PoE) - RJ-45
FCC, RoHS
PoE
10 - 90% (non-condensing)
Speed: 2402Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Protocol: 802.11ax
Compatibility: PC
Brand: TP LINK
