TP LINK 200MB Nano Powerline Ethernet Adapter
Quicklinx: 7S1BWS00 Mfr#: TL-PA211
New, Smaller Design
NB - Item contains 1 single unit for adding to existing kits such as qlinx-7KJ7
TP-LINK's powerline adapter TL-PA211 takes advantage of your home's existing electric wires to transfer data while transferring traditional power. That means, with no additional wiring required, users can simply plug the TL-PA211 into existing power sockets and establish networking infrastructure in a flash. With high-speed data transfer rates of up to 200Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks all at the same time now.
  • Super small design
    With the ultra-compact housing design, TP-LINK TL-PA211 is much smaller than most other 200Mbps powerline products. With its high quality, elegant shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.
  • Up to 200Mbps, 300 meters
    With advanced HomePlug AV technology, TL-PA211 provides you stable, high-speed data transfer rate up to 200Mbps on a line length up to 300 meters. Together with the built-in QoS and powerful AES encryption, TL-PA211 is such a good choice for a whole home solution to connect all network compatible devices - from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives - and supplies them with broadband Internet.
  • Pair button for easy network security
    Simply push the pair button on the adapters and then you can set up a hassle-free powerline network within minutes, which features 128-bit AES encryption for network security and data protection.
TP-Link TL-PA211 - powerline adapter - plug-in module
Powerline adapter
Enclosure Type
Plug-in module
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
200 Mbps
Network / Transport Protocol
TCP/IP
Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, HomePlug AV
5.6 cm x 9.3 cm x 3 cm
125 g
Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista
Powerline adapter
Enclosure Type
Plug-in module
Wired
Data Transfer Rate
200 Mbps
TCP/IP
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, Plug and Play, FCC, RoHS
1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
Internal power supply
3 Watt
Software Included
Drivers & Utilities
5.6 cm
9.3 cm
3 cm
125 g
10 - 90% (non-condensing)
