TP LINK RE505X AX1500 Wi-Fi 6 Range Extender
Quicklinx: FT7WWS00 Mfr#: RE505X
Type: Wi-Fi range extender
Speed: 1500Mbps
Connectivity: Wired, Wireless
Pass-through Socket: No
  • IEEE 802.11n
More than 50 In Stock
£55.25 ex VAT
£66.30 inc VAT
RE505X comes equipped with the latest wireless technology, Wi-Fi 6, for faster speeds, greater capacity, and reduced network congestion. Creates a Mesh network by connecting to a OneMesh router for seamless whole-home coverage.
The 505X wirelessly connects to your router, boosting your Wi-Fi 6 signal throughout your home so you can binge watch your favorite show anywhere. RE505X is more than just a wireless range extender. Simply plug an Ethernet cable into its port to easily turn that wired connection into a high-speed dual band wireless signal.
  • Gigabit Ethernet port
    Provide faster-wired connections to smart TVs, computers and gaming consoles.
  • Intelligent signal light
    Helps to determine the best location for optimal Wi-Fi coverage by indicating the signal strength in the current placement.
  • AP Mode
    AP Mode - create a new Wi-Fi access point to enhance your wired network with Wi-Fi capability.
  • TP-LINK Tether App
    Easily access and manage your network using any iOS or Android mobile device.
  • Ultimate compatibility
    Extend the range of any Wi-Fi router or wireless access point.
TP-Link RE505X - Wi-Fi range extender - Wi-Fi 6
External
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (5 GHz): 1200 Mbps , Maximum data rate (2.4 GHz): 300 Mbps
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows XP / Vista / 7 / 8 / 10
7.4 cm x 4.6 cm x 12.48 cm
280 g
7.4 cm
4.6 cm
12.48 cm
280 g
External
Wireless, wired
Data Transfer Rate
1500 Mbps
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1500
Status Indicators
Power, 5 GHz, 2.4 GHz, Wi-Fi
Access Point operational mode, Wi-Fi Protected Setup (WPS), reset button, Intelligent Signal Light, WPS button, 4K UHD video streaming, Wi-Fi 6 technology, OneMesh support, Adaptive Path Selection
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2-PSK
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.3ax
Aerial
Antenna
External
Antenna Qty
2
1 x 1000Base-T - RJ-45
FCC, RoHS
Internal power supply
10 Watt
Speed: 1500Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: TP LINK
