For a professional monitor solution packing practical performance as well as innovative features, choose the Samsung SA200 business monitor. You'll save energy costs and enjoy eco-friendlier operation thanks to efficient and lightweight design. With Adaptor On Off 0W, you can eliminate wasted energy during standby with the flick of a switch. Design innovations like adaptor neck stand, cable arrangement and detachable adaptor let you save space and reduce clutter for an optimised working environment. So, you'll save money and make the most of your time and workspace thanks to smarter technology.
Go green with Samsung's Adaptor On Off 0W
The ultimate energy saving measure has been created by Samsung with the new Adaptor On Of mode. By simply flicking the mechanical switch found on the Samsung LED Business monitor SA200, you can cut energy output while not using the monitor down to an amazing 0 Watts. Conventional standby modes reduce energy output to about 1 Watt, but the SA200 goes one stop further for greater results. This helps minimises both environmental impact and operating costs, and is just one more step by Samsung in creating a greener environment. -
Clear your desk with Samsung's Cable Arrangement
A tidy and clean workspace is paramount when it comes to showing professionalism at work. That's why the Samsung LED Business Monitor SA200 comes with a Cable Arrangement. It conveniently organises the cables coming from the monitor into a simple bundle along the stand and helps minimise clutter around the screen. With the Samsung LED Business Monitor SA200, you can finally enjoy a neat workspace, where annoying cables are kept out of sight. -
Maximise work space with the Adaptor Neck Stand
Samsung's unique and stylish Adaptor Neck Stand is perfect for any modern workplace. Exclusive to the Samsung LED Business Monitor SA200, its slim design ensures that workspace is maximised while also delivering a sophisticated and professional look. The simple manner in which it attaches to the monitor ensures that the set-up is clean and easy to manage. It is the perfect business solution for numerous situations‡ it could be for businesses with large amounts of PC-users or operations with restricted space. Either way, the Samsung LEDBusiness Monitor SA200 is ready to enhance work performance. -
Maximise workspace with an efficient detachable adaptor
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SA200 is the perfect choice. It features an innovative new detachable adaptor, which allows the monitor to be easily moved and installed. From physically moving the monitor with the carrying handle to quickly installing, the SA200 is ready to deliver an efficient and clean work space. The SA200 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimising your office space is now easily achieved with the Samsung LED Business Monitor SA200. -
Enjoy energy savings with the lightweight LED display
Samsung's lightweight LED Business Monitor SA200 provides another energy saving option through its low consumption levels. This reduction in energy helps both financial and environmental aspects of the business, and is an important part of any work operation. The LED Business Monitor SA200 is also remarkably lightweight and reduces the hassles associated with transporting monitors, and is just one more way that Samsung is helping enhance the working environment.
- Samsung SyncMaster S19A200NW - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Aspect Ratio
- Widescreen - 16:10
- Native Resolution
- 1440 x 900
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- 44.3 cm x 20.1 cm x 39.5 cm - with stand
- 3.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Design
- Simple Stand, Tilt stand, Vesa Wall Mount Support
- Display Type
- Diagonal Size
- 19"
- Aspect Ratio
- Native Resolution
- 1440 x 900
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 85
- Vertical Viewing Angle
- 80
- Backlight Technology
- LED backlight
- Power off timer, MagicColor, carrying handle, MagicAngle, MagicBright 3, power on timer, Mega Dynamic Contrast Ratio
- 3.1 kg
- VGA
Mechanical
- Tilt
- Flat Panel Mount Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Power Supply
- External
- 20 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - 44.3 cm x 20.1 cm x 39.5 cm x 3.1 kg , Without stand - 44.3 cm x 5 cm x 30.2 cm
