The Samsung Business Monitor SA450 is the perfect choice for professional businesses that are looking to increase overall operational efficiencies while boosting the performance and productivity of employees. These high-performance monitors are specially designed for working under extremely demanding conditions while providing its users with ergonomic features that will reduce fatigue. The new line up is also a born multitasker and can run more efficiently with lower power consumption. So whether you're in professional services, financial industry, or higher education, the SA450 will transform the way you and your employees conduct business.
- Samsung S24A450BW - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), tilt
- Matte black
- 56 cm x 20.1 cm x 40 cm - with stand
- 6.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, DDC-2B, ISO 9241-307, TCO '05
- 3 years warranty
- Display Type
- Diagonal Size
- 24"
- Aspect Ratio
- Widescreen
- Native Resolution
- 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 61 Hz
- Horizontal Refresh Rate
- 75 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3
- Matte black
- 6.7 kg
- VGA , DVI-D
Mechanical
- Tilt Angle
- 25
- Height Adjustment
- 100 mm
- Wall mountable
- Power Supply
- External
- 29 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - 56 cm x 20.1 cm x 40 cm x 6.7 kg , Without stand - 56 cm x 5 cm x 37.4 cm x 5.1 kg
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years - pick-up and return
