Samsung S23C650D 23 LED VGA DVI Monitor
Choose a Samsung Series 6 LED business monitor and discover maximized viewing for maximum productivity. With a stylish narrow bezel, you can make the most of the screen and reduce distraction. Thanks to an ultra-wide 178-degree viewing angle, you can see screen contents perfectly from all around the room and even share it with nearby colleagues. You'll always enjoy a clear, detailed and vivid picture. Meanwhile, the built-in USB hub lets you connect your keyboard, monitor and other USB devices, removing the need for a docking station.
Key Features
- Experience minimal design and maximum effect
- See perfect colors from wherever you sit
- See your work from the best possible angle
- The USB hub that sets you free
- Maximize your space with easy wall mounting
- Keep your work space as efficient as your monitor
- Improve your work with HAS design
- Upgrade to the next level with mega dynamic contrast
Product Features
Maximize your monitor experience with the help of a chic narrow bezel, that helps reduce distraction when looking at the monitor and therefore increase the levels of concentration. The extra screen space also makes it easier to set up a dual monitor workstation, which also adds to work productivity. For those who just want a smart looking monitor, the narrow bezel adds a sophisticated look and feel to any desk.
Maximize your viewing experience with Samsung's superior AD-PLS technology. The SC650, which can cover an amazing 178-degree viewing angle both vertically and horizontally, boasts a crisp and detailed picture by maintaining true-to-life color, even when viewed from extreme angles, so the experience is always vivid and brilliant.
Provide employees with an optimal viewing experience in the office with the reasonably priced Samsung business monitor. While conventional monitors have a viewing angle of 170-degree horizontally, the Samsung monitor has an extra wide viewing angle of 178-degrees. The additional 8 degrees is particularly useful when sharing on-screen information with one or more coworkers or presenting your ideas to clients. The Samsung business monitor has improved its vertical viewing angles by 18-degree, making it the perfect display for giving presentations in front of a large audience or when viewing other content such as a video.
Streamline your desk with simple and hassle-free connectivity. The built-in USB Hub features 2 USB ports and replaces the need for a docking station. Furthermore, the enhanced connectivity also means that all your devices can be connected and controlled through the monitor. So, everything from your mouse and keyboard to your external speakers, printers and USB devices can simply connect to your Samsung business monitor. This monitor really sets your PC free!
Give your monitor the best possible positioning with the VESA wall mount. Easy to mount and install, it is convenient, safe and perfectly compatible with your monitor. You will always have a great viewing angle and will make the most of your space thanks to the monitor.
If you need a work monitor that uses office space efficiently, then Samsung LED business monitor SC650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing it, the SC650 is ready to deliver an efficient and clean work space. Optimizing your office space is now easily achieved with the Samsung LED business monitor SC650.
Find the perfect viewing experience with the help of Samsung's Height Adjustable Stand (HAS). Its simple controls allow for users to tailor their monitor height and angle to meet their exact eye level and therefore improve their productivity when working. It ensures that users are always benefitting from the best.
Mega dynamic contrast ratio delivers new levels of color and picture quality to your viewing experience with images that are real-to-life. A breathtaking Mega8 DCR contrast ratio shows blacks at their absolute darkest and pristine whites and other colors at their brightest. You will notice the crystal clear picture clarity. It is like an explosion of color that make other screens seem dull in comparison. Enjoy your multimedia content with the professionalism it deserves.
Product Specifications
Product Description Samsung S23C650D - LED monitor - 23"
Device Type LED-backlit LCD monitor - 23"
Built-in Devices USB Hub
Panel Type AD-PLS
Aspect Ratio Widescreen - 16:9
Native Resolution FullHD 1920 x 1080
Pixel Pitch 0.2655 mm
Brightness 250 cd/m2
Contrast Ratio 1000:1 / 5000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Matte black
Dimensions (WxDxH) 54.29 cm x 22.4 cm x 34.965 cm - with stand
Weight 5.45 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV, C-Tick, GOST, EN55022, NEMKO, NOM, PCBC, SASO, SIQ, EN55024, CISPR 22, CCC, PSB, AS/NZS 3548, IRAM, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1, FCC Part 15 B Class A, VCCI V-3, KC, GB 9254-2008, GB 4943-2001 PSB, NOM-019-SCFI-1993 IRAM, GB 17625.1-2003 EMC, K60950-1, KCC KN22, KCC KN24
Manufacturer Warranty 3 years warranty
