Experience amazing levels of color, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SD300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SD300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves.
Upgrade to the next level with Mega Dynamic Contrast
Experience amazing levels of color, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SD300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SD300 monitor ensures that blacks are at their absolute darkest and colors are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colors and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio - and enjoy your multimedia content with the professionalism it deserves. -
Control brightness, conserve energy
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes, you can really tailor your monitor use to meet your own personal needs. Samsung's commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with eco saving. -
See it your way with wider viewing angles
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes center stage and that you're always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favorite movies and other multimedia in total comfort and without limitations thanks to magic angle.
- Samsung S22D300HY - SD300 Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 31 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- High glossy black
- 51.16 cm x 17.7 cm x 38.52 cm
- 2.9 kg
- RoHS
- Display Type
- Energy Class
- Class B
- 31 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Power off timer, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale
- High glossy black
- 51.16 cm x 17.7 cm x 38.52 cm - with stand
- 2.9 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -1/+20
- Cables Included
- 1 x VGA cable
- RoHS
- Power Supply
- External
- Input Voltage
- 21 W
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.3 Watt
- OS Required
- Apple MacOS, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 51.16 cm - depth: 17.7 cm - height: 38.52 cm - weight: 2.9 kg , Without stand - width: 51.16 cm - depth: 5.31 cm - height: 31.08 cm - weight: 2.65 kg
Accessories (4)
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
Other bundles (1)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
