You can experience awesome LED pictures with natural colors. The elegant design with translucent blue bezel and SmartImage Lite makes it a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
- Philips E-line 227E3LSU - LED monitor - 21.5"
- LED-backlit LCD monitor - 21.5"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- FullHD 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA
- Tilt
- Glossy, black/blue
- 53.4 cm x 21.6 cm x 40.8 cm - with stand
- 3.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge
- Display Type
- Diagonal Size
- 21.5"
- Aspect Ratio
- Widescreen - 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m2
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
- Sync on Green, sRGB colour management, HDCP, SmartImage Lite, Touch Control
- 3.7 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- 25
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V ( 50/60 Hz )
- 18.5 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Dimensions & Weight Details
- With stand - 53.4 cm x 21.6 cm x 40.8 cm x 3.7 kg , Without stand - 53.4 cm x 4.1 cm x 33.6 cm x 3.5 kg
- 0 °C
- 40 °C
- 20 - 80%
