Philips B Line 276B9 27" 2560x1440 4ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: G6F2WS00 Mfr#: 276B9/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
Hurry, only 2 left in stock!
£202.10 ex VAT
£242.52 inc VAT
Simplify your connections
View Quad HD image and re-charge your laptop all at the same time with a single USB-C cable. SmartErgo base, Flicker-free and LowBlue mode make work easy-on-the eyes.
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high-resolution video and transfer data at super speed, while powering up and recharging your compatible device at the same time.
Crystal clear images with Quad HD 2560 x 1440 pixels
These Philips screens deliver Crystal Clear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilising high-performance panels with high-density pixel count, enabled by high-bandwidth sources like Displayport, HDMI and Dual link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, a user of 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystal Clear images.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
PowerSensor saves up to 80% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life.
HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
Power and re-charge compatible notebook from the monitor
This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible* Notebook directly from the Monitor using a single USB-C cable.
  • SmartErgoBase
  • Flicker-Free technology
  • LowBlue Mode
  • PowerSensor
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and then automatically reduces monitor brightness when then user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life
  • IPS technology
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • HDMI Ready
  • CrystalClear images
  • USB-C connection
Philips B Line 276B9 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
26.1 W
USB Hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 75 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
114% sRGB (CIE 1931), 90% NTSC (CIE 1976)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
61.4 cm x 22.4 cm x 55.8 cm
7.75 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, PSE Mark, MEPS, CECP, CEL, EPA, RCM, CU-EAC, BFR-free, Ukraine, PVC-free, Mercury-free, EAEU RoHS
3-year warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Built-in Devices
USB Hub
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.79
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 114 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
PowerSensor, SmartImage, Smart Ergo base, Low Blue Light Mode, Flicker Free technology, EasyRead, sRGB Mode
Black texture
61.4 cm x 22.4 cm x 55.8 cm - with stand
7.75 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 , USB-C upstream , 3 x USB 3.2 downstream (power up to 65W) , USB 3.2 downstream (fast charging) , Audio line-out
Mechanical
Tilt Angle
-5/+30
Swivel Angle
350
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), DisplayPort Alt Mode
DisplayPort cable , HDMI cable , USB-C cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
26.1 W
26.1 kWh/1000h
Power Consumption (Typical)
18.6 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 61.4 cm - depth: 22.4 cm - height: 55.8 cm - weight: 7.75 kg , Without stand - width: 61.4 cm - depth: 6.1 cm - height: 37.2 cm - weight: 5.3 kg
Shipping Width
69 cm
Shipping Depth
25 cm
Shipping Height
46.2 cm
Shipping Weight
10.62 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
20 - 80%
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Philips
