Enjoy vibrant pictures on this Philips display. Equipped with HDMI and SmartControl lite, it's a great choice!
SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse. -
SmartContrast
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
Mercury Free
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal. -
16:9 Full HD display
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
HDMI Ready
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
IPS-ADS technology
IPS-ADS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
- Philips V-line 240V5QDSB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 37 kWh
- Power Consumption (On mode)
- 25 W
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black, black hairline
- 55.3 cm x 21.9 cm x 42 cm
- 4.09 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, C-Tick, BSMI, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, EPA, cETLus
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 37 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- ADS-IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartResponse, SmartContrast, 4:3 in Wide, SmartControl Lite, Mercury free
- 55.3 cm x 21.9 cm x 42 cm - with stand
- 4.09 kg
- VGA , HDMI (HDCP) , DVI-D (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 25 W
- Power Consumption (Typical)
- 19.23 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 55.3 cm - depth: 21.9 cm - height: 42 cm - weight: 4.09 kg , Without stand - width: 55.3 cm - depth: 5.5 cm - height: 34.3 cm - weight: 3.69 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 20 - 80%
