The Philips Brilliance monitor with HDR delivers a wider range of color and brilliance for the most life-like images. With an expansive crystal-clear QHD IPS display, see the big picture with all the details.
Power and re-charge compatible notebook from the monitor
This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible* Notebook directly from the Monitor using a single USB-C cable. -
View Crystalclear QHD 2560 x 1440 images
These Philips screens deliver CrystalClear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilising high-performance panels with high-density pixel count, enabled by high-bandwidth sources like USB-C, Displayport, HDMI and Dual-link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, are using 3D graphic applications or are a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images. -
Pro colour standards 99% Adobe RGB, 100% sRGB
Meeting professional industry-standard colour, this monitor offers Adobe 99% and 100% sRGB colour spectrum. The enhanced colour rendering range of Adobe RGB makes it ideal for professional photo and video editing, animation or work with colour-critical projects. You can now be confident that your colour is consistent and true to the original image. -
10-bit IPS technology for full colours and wide viewing angle
This Philips monitor uses a native 10-bit wide view angle display. This enables you to view consistent and smooth images with a colour depth of 1.07 billion colours, vs an 8-bit display which is limited to only 16 million possible colours. With a suitable graphics card and appropriate software, you can now work on your colour-critical professional work with ease. -
100% recyclable packaging
Philips is committed to use sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In selected models, we utilize >= 65% Post-Consumer Recycled plastics, ensuring reduction in waste. Strict adherence to RoHS standards ensure substantial reduction or elimination of toxic substances like Lead and Mercury. Our display housing is made up of PVC/BFR free material. -
PVC-BFR free housing
This Philips monitor housing is free from brominated flame retardant and polyvinyl chloride (PVC-BFR free) -
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time. -
Connect your notebook with one USB-C cable
This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high resolution video and transfer data at a super-speed, while powering up and re-charging your compatible device at the same time. -
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
High Dynamic Range (HDR) for more lifelike colourful visuals
High Dynamic Range delivers a dramatically different visual experience. With astonishing brightness, incomparable contrast and captivating colour, images come to life with much greater brightness while also featuring much deeper, more nuanced darks. It renders a fuller palette of rich new colours never before seen on a display, giving you a visual experience that engages your senses and inspires emotions.
- Philips Brilliance P-line 328P6AUBREB - LED monitor - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Class
- Class E
- Energy Consumption per Year
- 95 kWh
- Power Consumption (On mode)
- 39.9 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2727 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 1200:1 / 50000000:1 (dynamic)
- HDR Capable
- HDR10
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 99% Adobe RGB (CIE 1973)
- Input Connectors
- HDMI, VGA, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Textured black
- 74.2 cm x 27 cm x 65.7 cm
- 9.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- DDC/CI, RoHS, Lead-Free
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class G
- 95 kWh
- Diagonal Size
- 32"
- Viewable Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2727 mm
- Pixel Per Inch
- 93
- Brightness
- 450 cd/m²
- Contrast Ratio
- HDR Format
- HDR10
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, SmartUniformity, USB 3.0 Fast Charge, EasyRead
- Textured black
- 74.2 cm x 27 cm x 65.7 cm - with stand
- 9.7 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DisplayPort , HDMI , VGA , USB-C , 2 x USB 3.0 downstream , Audio line-in , Headphones , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 340
- Rotation Angle
- 90
- Height Adjustment
- 180 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 70,000 hour(s)
- Input Voltage
- 39.9 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption HDR (On mode)
- 54.9 kWh/1000h
- Power Consumption (Typical)
- 32.4 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- Dimensions & Weight Details
- With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 9.7 kg , Without stand - width: 74.2 cm - depth: 6.3 cm - height: 43.8 cm - weight: 6.74 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
