NETGEAR ProSafe 802.11g Wireless Access Point
LIFETIME WARRANTY
Quicklinx: 64XHWS00 Mfr#: WG103-100UKS
  • Wi-Fi CERTIFIED
NETGEAR's Wireless Access Point ProSafe WG103 is ideal for extending an existing Ethernet network to areas that cabling cannot reach, or to provide easier connectivity for visitors, a mobile workforce or hot desking staff.
NETGEAR WG103 - radio access point
Radio access point
External
United Kingdom
RAM
32 MB
Flash Memory
8 MB
IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Connection / user qty: 128 , Virtual interfaces (VLANs): 9
Power Over Ethernet (PoE) Supported
PoE
15.8 cm x 10.1 cm x 2.9 cm
403 g
NETGEAR lifetime warranty
Radio access point
15.8 cm
10.1 cm
2.9 cm
403 g
United Kingdom
Processor / Memory / Storage
RAM
32 MB SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
108 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
Power, test mode
Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, 40-bit WEP, SSL, WPA-PSK, WPA2-PSK, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID)
IEEE 802.11, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
Aerial
Antenna
External detachable
Antenna Qty
1
Directivity
Omni-directional
Gain Level
5 dBi
1 x 100Base-TX (PoE) - RJ-45
1 x network cable
PoE
External power adapter
Software Included
Drivers & Utilities
