The right features and a crisp, clear presentation, combined with a thoughtful design provide you with a smart investment for today and into the future. Enjoy clear, sharp HD pictures, easy connectivity and comfortable use with the Dell E1913S monitor. Invest in a reliable, energy-conscious monitor designed to help minimize environmental impact, maximize value, and control energy costs.
Brighten your view of day-to-day business
Meet your everyday business needs with the reliable and efficient Dell E1913S monitor, offering the essential features you need to get the job done. -
Envision smart features and easy connectivity options that help get the job done
The right features and a crisp, clear presentation, combined with a thoughtful design provide you with a smart investment for today and into the future. -
Outstanding features and reliability
Enjoy clear, sharp HD pictures, easy connectivity and comfortable use with the Dell E1913S monitor. -
Protect your investment and the environment
- Dell E1913S - E Series - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.19 cm x 16.35 cm x 40.86 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- LED backlight
- Anti-glare, PowerNap
- Black
- 41.19 cm x 16.35 cm x 40.86 cm - with stand
- VGA
Mechanical
- Tilt
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- Without stand - width: 41.19 cm - depth: 5.2 cm - height: 33.67 cm - weight: 2.79 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
