Dell P2423D 23.8" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: H3MRWS00 Mfr#: DELL-P2423D
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: [N/A]
Interfaces: DisplayPort, HDMI
41 In Stock
£197.26 ex VAT
£236.71 inc VAT
Stay focused on a 23.8-inch QHD monitor optimized to deliver high performance details and clarity.
Dell P2423D - LED monitor - QHD - 23.8" - TAA Compliant
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
16 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.78 cm x 17.957 cm x 49.611 cm
5.45 kg
TAA Compliant
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Arsenic-free glass
53.78 cm x 17.957 cm x 49.611 cm - with stand
5.45 kg
DisplayPort 1.2 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 cable - USB Type A to B
TAA Compliant
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Max)
55 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.78 cm - depth: 17.957 cm - height: 49.611 cm - weight: 5.45 kg , Without stand - weight: 3.44 kg
Shipping Weight
7.44 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
Accessories (1)
H3MR Dell Dual Monitor Stand - MDS19 In Stock £149.14
Other bundles (3)
H3MR Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.58
H3MR Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £141.12
H3MR Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.51
Response Time: 5ms
Speakers: [N/A]
Interfaces: HDMI
Brand: Dell
