The Powerline AV Passthrough Mini Adapter Starter Kit uses your home's existing electrical wiring to extend your Internet connection. It turns every power outlet into a high speed network connection. Compliant with the HomePlug AV standard, it provides network access to your computers, game consoles, televisions, and any other Internet-enabled devices throughout your home. The built-in Passthrough design enables you to continue using your electrical socket by plugging another device into the integrated electrical outlet. The Passthrough socket features noise filtering which helps prevent the electrical device plugged into the socket from affecting your Powerline connection and performance. Also available as a single unit (DHP-P308AV).
This Powerline AV Passthrough Mini Adapter Starter Kit is compliant with the HomePlug AV standard and capable of delivering data transfer rates at speeds of up to 200 Mbps, faster than regular Powerline AV products. This rapid transmission speed makes it ideal for bandwidth-intensive applications, guaranteeing smooth HD video streaming, VoIP phone calls, and lag-free online gaming experiences. This device provides ample network bandwidth, enabling you to tap into existing electrical wiring for high-quality multimedia streaming. Additional Quality of Service (QoS) support prioritizes multimedia traffic over other types of traffic on your network connection, ensuring faster transmission.
Plugs directly into a power outlet, and does not require any additional cables. Extend your home network by connecting multiple devices in the farthest corners of your home, or attach a switch or wireless access point to the adapter to connect even more devices. The adapter implements 128-bit AES data encryption at the push of a button to protect your network from any intruders. With hassle-free plug and play installation, it's an ideal solution to create a wall-to-wall home network.
During periods of inactivity, the Mini Adapters will go into sleep mode to save power, reducing power usage by more than 70%, allowing you to save energy automatically without sacrificing on performance.
Easily expand your network
This convenient starter kit contains everything you need to extend your home network to where your wireless signals cannot reach. -
Fast network performance
Up to 200 Mbps for faster sharing, lag free gaming and smooth HD video streaming. -
Plug and play
No need for any IT or networking knowledge. Simply plug one adapter into any power outlet and connect it to your router, and the other adapter to your Internet-enabled device, such as computers, smart TVs or games consoles. -
Secure network sharing
Secure your network from unwanted connections with a simple push of a button. -
Passthrough design
Enables you to continue using your electrical socket by plugging another device into the integrated electrical outlet.
- D-Link PowerLine DHP-P309AV - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV), IEEE 1901
- Data Transfer Rate
- 200 Mbps
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), D-Link Green Technology
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 5.8 cm x 7.9 cm x 3.94 cm
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 200 Mbps
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, UL, FCC
- Status Indicators
- Port status, power
Line Properties
- Line Coding Format
- OFDM
- 1 x IEEE 1901 , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 2.7 Watt
- 5.8 cm
- 7.9 cm
- 3.94 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
