AOC I960PRDA 19" 1280x1024 6ms DVI-D IPS Monitor
Quicklinx: B8NLWS00 Mfr#: I960PRDA
This model targets business and home office users alike. Hidden behind its classically designed case is the latest LED technology. It boasts a high typical contrast, an ultra-fast response time and wide viewing angles for excellent imaging performance. With the i-Care function, the monitor adapts the panel's brightness to the ambient light. This means a more comfortable viewing experience, whilst lowering the energy consumption at the same time. The environmentally friendly display comes in an elegant, textured black finish.
  • Integrated Speakers
    Built-in speakers make it easy to catch up with family, friends and colleagues. For movies, music, games and more, you'll enjoy quality audio without the hassle of connecting external speakers.
  • Height adjustable stand
    We care about your well-being. This is why this monitor offers height adjustment options, which help you find your perfect posture while working, playing or watching videos. Adapting your AOC monitor to your needs not only helps you reduce fatigue and keep your body healthy. In the end it lets you and your team achieve better results in whatever you are doing.
  • Kensington Lock
    Kensington Lock is an anti-theft system, comprising a metal-reinforced hole in the body of the respective device, to use with a metal cable secured with a key/lock system. Kensington locks enable you to secure your AOC monitor during a LAN event, an organisation, or wherever you carry it.
AOC Pro-line I960PRDA - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class E
Power Consumption (On mode)
14.6 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms (grey-to-grey)
Input Connectors
DVI-D, VGA
Display Position Adjustments
Height, pivot (rotation), swivel
Voltage
AC 230V (50/60 Hz)
40.92 cm x 43.22 cm x 21 cm
4.77 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, EAC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 80 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
OSD Languages
Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean
I-Menu, e-Saver technology, Eco Saving, Screen+, i-Care
4.77 kg
Audio
Speakers
VGA , DVI-D , Headphones
Mechanical
Tilt Angle
-5/+20
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x power cable
Power Supply
Internal
Input Voltage
AC 230V (50/60 Hz)
14.6 W
14.6 kWh/1000h
Power Consumption (Typical)
16 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.21 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
B8NL C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
