Productivity anywhere you go
More screen real-estate significantly increases productivity. With your monitor connected to your laptop you can be efficient even outside your home or office – when travelling or, visiting customers.
USB monitor 3.0
Discover the freedom and flexibility of AOC’s myConnect USB monitors. A single USB cable connects your laptop to the directly to the display, completely eliminating the need for extra media cables and a power supply. The USB cable transfers data to the screen, plus acts as an energy-efficient power source. For work or play, these monitors offer optimal portability. Besides ultra-easy connectivity, the innovative stand offers you a variety of viewing options.
Flexi-Stand
The E1659FWU has a foldable flexi-stand for viewing in landscape or portrait mode. Landscape mode is ideal for video conferences, presentations and Excel sheets, while the Portrait mode conveniently gives you an easy vertical view of your instant messaging program, or sidebars such as search results.
Auto-Pivot
Change the orientation of the monitor to automatically align screen content (included AOC i-Menu software needed to activate).
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
USB monitor
Discover the freedom and flexibility of AOC's myConnect USB monitors. A single USB cable connects your laptop to the directly to the display, completely eliminating the need for extra media cables and a power supply. The USB cable transfers data to the screen, plus acts as an energy-efficient power source. For work or play, these monitors offer optimal portability. Besides ultra-easy connectivity, the innovative stand offers you a variety of viewing options.
- AOC E1659FWU - LED monitor - 15.6"
- LED-backlit LCD monitor - 15.6"
- Energy Class
- Class C
- Power Consumption (On mode)
- 8 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.252 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 500:1 / 20000000:1 (dynamic)
- Colour Support
- 16.7 million colours (8-bit)
- Input Connectors
- USB
- Tilt
- Glossy piano black
- 36.98 cm x 2.22 cm x 21.914 cm
- 1.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC, RoHS, cTUVus, cCSAus
- 3-year warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 15.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.252 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Backlight Technology
- WLED
- FlexStand
- 1.2 kg
Mechanical
- Tilt
- VESA Mounting Interface
- 75 x 75 mm
- Included Accessories
- Carrying case
- Backlight Life
- 50,000 hours
- 8 W
- Power Consumption SDR (On mode)
- 8 kWh/1000h
- Power Consumption (Typical)
- 7 Watt
- Power Consumption Stand by
- 0.03 Watt
- 0 Watt
- Shipping Width
- 44.2 cm
- Shipping Depth
- 8.5 cm
- Shipping Height
- 29.5 cm
- Shipping Weight
- 1.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
