e2752Vq LED backlight panel saves the environment, containing no toxic mercury and using only half the power of traditional CCFL screens. Ultra-high dynamic contrast of 20,000,000:1 reveals more depth and detail in darker scenes. To enhance your total viewing pleasure, the monitor design is slim and streamlined, with discreetly concealed control buttons. Digital and power connectors are rear-facing for direct insertion, more convenient than more common downward-pointing ports.
Fast 2ms response time
These displays make sure you'll never miss out on the action. Quick 2ms response time virtually eliminates ghosting and blur, making it ideal for gaming, watching movies or editing videos.From high-speed car chases to fast-paced combat, you'll always enjoy an immersive, lag-free viewing experience. -
Three-Year Warranty
AOC stands behind the quality of each and every monitor with a generous three-year warranty starting from the original date of purchase. Within the warranty period, any AOC displays with manufacturing defects or faulty components will be repaired or replaced at no additional charge. Read the complete AOC warranty statement for more information. -
HDMI input
High Definition Multimedia Interface or HDMI is a global standard for digitally transmitting high-definition video and multichannel audio. This versatile single-cable solution allows you to easily connect your display to devices like computers, laptops, game consoles and media players.
- AOC e2752Vq - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A+
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 20000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 64.6 cm x 21 cm x 45.2 cm
- 5.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, VCCI, BSMI, GOST, DDC-2B, FCC, DDC/CI, RoHS, ISO 9241-307, KCC, J-MOSS
- Display Type
- Energy Class
- Class A+
- 34 kWh
- Diagonal Size
- 27"
- Built-in Devices
- Stereo speakers
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume
- HDCP
- Black
- 64.6 cm x 21 cm x 45.2 cm - with stand
- 5.3 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2.5 Watt
- VGA , DVI-D , HDMI , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -3/+17
- VESA Mounting Interface
- 100 x 100 mm
- Power Supply
- Internal
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by / Sleep
- 0.6 Watt
- 0.4 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
