Single Unit
The ZyXEL PLA5205 600 Mbps Powerline Gigabit Ethernet Adapter improves networking performance by more than 20% comparing to the 500 Mbps powerline technology for more stable multiple-HD media streaming. Just plug a pair of PLA5205 into the electrical outlets and connect your network devices to them to immediately enjoy HD multimedia streaming, multiplayer gaming and other network applications simultaneously in every room.
The ZyXEL PLA5205 gives you the installation flexibility to turn power lines into a home network without blocking power outlets nearby. Data transmission is protected by the 128-bit Advanced Encryption Security (AES) mechanism to provide a secure connection to the Internet. Encryption can be configured with a simple button press - no complicated setup or additional software required.
Superior network performance and coverage with Gigabit Powerline adapter
The ZyXEL PLA5205 600 Mbps Powerline Gigabit Ethernet Adapter improves networking performance by more than 20% comparing to the 500 Mbps powerline technology for more stable multiple-HD media streaming. Just plug a pair of PLA5205 into the electrical outlets and connect your network devices to them to immediately enjoy HD multimedia streaming, multiplayer gaming and other network applications simultaneously in every room. -
HomePlug AV2 with Gigabit Ethernet port
With the latest HomePlug AV2 technology, the ZyXEL PLA5205 provides speeds up to 600 Mbps and backward compatibility with HomePlug AV and IEEE 1901-based products. In addition, the PLA5205 is equipped with a Gigabit Ethernet port to provide a stable, high-performance network for simultaneous HD streaming, gaming and web browsing. You can easily extend Internet access to any room with just a power outlet. -
Plug-and-Play and easy security setup
The ZyXEL PLA5205 gives you the installation flexibility to turn power lines into a home network without blocking power outlets nearby. Data transmission is protected by the 128-bit Advanced Encryption Security (AES) mechanism to provide a secure connection to the Internet. Encryption can be configured with a simple button press - no complicated setup or additional software required. -
QoS enhances media streaming quality
The advanced Quality of Service (QoS) feature improves the quality of multimedia streaming applications such as triple-play services by traffic prioritizing HD video streaming, high-speed Internet access and VoIP services.
- Zyxel PLA5205 - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901
- Data Transfer Rate
- 600 Mbps
- CSMA/CA
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- TR-069
- 128-bit encryption, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), reset button, SmartLink Plus
- HomePlug AV, HomePlug AV 2.0, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 8.1 cm x 2.8 cm x 5.6 cm
- 94 g
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- Localisation
- United Kingdom
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 600 Mbps
- CSMA/CA
- Routing Protocol
- TR-069
- Encryption Algorithm
- 128-bit AES
- HomePlug AV, HomePlug AV 2.0, IEEE 1901, FCC, LVD
- Status Indicators
- Power, link/activity
- LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x HomePlug AV 2.0
- Power Device
- Internal power supply
- Voltage Required
- 4.5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 8.1 cm
- 2.8 cm
- 5.6 cm
- 94 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
