Zyxel USG40 10/100/1000, 3x LAN/DMZ, 1x WAN, 1x OPT, UTM Bundle
Quicklinx: 9HXLWS00 Mfr#: USG40-EU0102F
The advancements in how people work and collaborate have brought three major challenges to small businesses. With the BYOD trend, small businesses today need to provide more Wi-Fi for an exploding amount of smart devices. The use of cloud-based social and productivity applications not only requires small businesses to be able to control, prioritize and block different applications to stay productive, but also opens doors to new web attacks. As threats evolve and these business challenges diversify, IT costs will only continue to grow, which is a real problem for small businesses with limited IT resources.
The ZyXEL USG performance series are all-in-one Next Generation Firewalls (NGFW) specifically designed to fulfill the demands BYOD, malware protection, application regulation, and budget control in small business environments. The built-in wireless AP and WLAN controller offer instant wireless hotspot capability and future WLAN scalability. Comprehensive UTM features and application intelligence technology provides deep, extensive protection, while keeping businesses in control of how web applications are used. The all-in-one design integrates everything small businesses need, delivering easier, more centralized management and lower total cost of ownership (TCO).
  • Spend less, get more
    The ZyXEL USG Performance Series offers small businesses the lowest total cost of ownership. The all-in-one design provides everything small businesses need: anti-malware protection, VPN connectivity, integrated WLAN controller, and built-in wireless access point. This truly integrated security solution eliminates the need to purchase multiple appliances for different functions, and allows small businesses to connect, protect and manage with just one device.
  • Peace of mind security
    The ZyXEL USG Performance Series delivers enterprise-grade Next Generation Firewall security without the hefty price tag. It provides deep, extensive protection and effective control of Web applications - like Facebook, Google Apps and Netflix - with such anti-malware protection mechanisms as firewall, ant-virus, anti-spam, content filtering, IDP and application intelligence. No longer do small businesses need to worry about threats, spam or social networking sites decreasing productivity.
  • Wi-Fi where you need it
    Addressing the trend of BYOD, the ZyXEL USG Performance Series helps small businesses provide Wi-Fi wherever there is demand. The USG40W features built-in single-radio and dual-radio wireless access points that can provide Wi-Fi for small offices straight out of the box. With an integrated WLAN controller, the USG Performance Series enables businesses to easily provide Wi-Fi in multiple other areas like reception areas and meeting rooms when Wi-Fi demand grows.
  • Single point of management
    Designed specifically for businesses with limited IT resources, the ZyXEL USG Performance Series helps users connect, protect and manage with reduced complexity. The unified security policy design offers easier, more unified and streamlined management of all the security features; while the integrated WLAN controller provides centralized management of up to 10 APs. All this is integrated into a single solution, making it easy for users to manage VPN, wireless and security all from one device.
Zyxel USG40 - UTM Bundle - security appliance - with 1 year AV+IDP, AS, CF
Security appliance
Bundled Services
Licence Qty
2 SSL VPN users
External
Europe
Performance
Firewall throughput: 400 Mbps , VPN throughput: 100 Mbps , Intrusion detection and prevention throughput: 55 mbps , Antivirus throughput: 50 Mbps
User licences: unlimited , Concurrent IPSec VPN tunnels: 10 , Concurrent sessions: 20000 , Concurrent SSL VPN users: 7 , Virtual interfaces (VLANs): 8 , New sessions: 3000 , Manageable access points: 10
21.6 cm x 14.3 cm x 3.3 cm
890 g
5-year warranty
Security appliance
Bundled Services
21.6 cm
14.3 cm
3.3 cm
890 g
Europe
External
Wired
Network / Transport Protocol
L2TP, IPSec, PPPoE, SMTP, DHCP, POP3, IMAP4
Routing Protocol
OSPF, RIP-1, RIP-2, GRE
Remote Management Protocol
Telnet, SNMP 2c, HTTP, HTTPS, SSH
Performance
Status Indicators
Port status, power, system
Firewall protection, DMZ port, routing, DHCP support, NAT support, VPN support, PAT support, SNAT support, load balancing, LDAP support, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, dynamic DNS server, manageable, stackable, E-mail alert, IPv6 support, antivirus analysis, High Availability, firmware upgradable, DDos attack prevention, tunnelling, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, anti-spam protection, Access Control List (ACL) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), SSH support, VPN failover, DHCP server, IPv4 support, 3G USB Dongle Support, DHCP relay, IP-MAC binding, CAPWAP support, DHCP client, dual firmware images, static routing, tagged VLAN, Captive Portal, Generic Routing Encapsulation (GRE), Intrusion Detection and Prevention (IDP), VPN concentrator, VPN load-balancing, VPN auto-reconnection, Single Sign-On (SSO) support
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, PKI, 256-bit AES, IKEv2, 512-bit SHA-2
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.1Q, X.509
3 x 1000Base-T - RJ-45 (LAN / DMZ) , 1 x 1000Base-T - RJ-45 (WAN) , 1 x 1000Base-T - RJ-45 , 1 x USB - Type A , 1 x console - RJ-45
MTBF
414,329.4 hours
ICSA IPSec certified, ICSA Firewall certified, ICSA Antivirus
External power adapter
14 Watt
Limited warranty - 5 years
