Zyxel MG-108 8 Ports Desktop 2,5G MultiGig unmanaged Switch
Quicklinx: HHYXWS00 Mfr#: MG-108-ZZ0101F
11 In Stock
£100.04 ex VAT
£120.04 inc VAT
The Zyxel 2.5 Gigabit Switch MG-108 is the perfect candidates to upgrade your network speed and performance, bringing you up to 2.5 times faster experience than today's Gigabit network. Unlike traditional gigabit switches, the MG-108 supports 2.5G for all its Ethernet ports which can boost the entire network performance up to 2.5Gbps at once without compromising to limited high-speed port availability. Out-of-the-box network speed upgrade turns MG-108 into an optimal solution for home or small office users who needs more bandwidth for their network with demands coming from online gaming activities, multimedia streaming services or faster wireless network connectivity without the complex configuration.
  • Upgrade network to multi-Gig
    MG-108 come with five/eight 2.5 Gigabit ports to optimize performance of your Multi-Gig bandwidth and devices, and provide 25/40 Gbps of switching capacity. They are an ideal choice for LAN parties, home entertainment, SoHo and offices.
  • Plug-n-Play, enjoy high speed network
    Easily connect MG-108 to the 2.5G-capable network devices such as 2.5G NAS, 2.5G PCIe adapter, gaming console, VR gaming, WiFi 6 AP, 4K video, desktop, and more and more to instantly enjoy high performance networking and smoother home entertainment experience with its simplified plug-and-play technology.
  • Use your existing cables
    The Multi-Gigabit RJ-45 ports not only provide more speed options for your network, but it can increase your home networking speed from current 1Gbps to 2.5Gbps without additional cabling fee!
  • Fanless design for true silent operation
    MG-108 is built with fanless and sturdy hardware design to ensure all-time silent and stable operation. They are perfect for every home or business environment.
  • Flexible deployment in your room
    The mounting option gives you the flexibility to place the 2.5G switch on a desktop or mount it to a wall.
Zyxel MG-108 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
2.5 Gigabit Ethernet
Ports
8 x 100/1000/2.5G Base-T
Performance
Switching capacity: 40 Gbps , Forwarding performance: 29.8 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), wall mountable, QoS, fanless, 12MB packet buffer
IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3bz
AC 100-240 V (50/60 Hz)
24 cm x 10.6 cm x 2.6 cm
640 g
Enclosure Type
Desktop
Subtype
Ports
Performance
16K entries
Jumbo Frame Support
12KB
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link/activity
8 x 100/1000/2.5G RJ-45
External power adapter
12.24 Watt
Plug and Play, FCC, BSMI Class B, EAC
24 cm
10.6 cm
2.6 cm
640 g
Shipping Width
25.6 cm
Shipping Depth
13.2 cm
Shipping Height
7.8 cm
Shipping Weight
1.122 kg
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Brand: Zyxel
