Experience unprecedented CPU performance in a compact form factor with the ZOTAC ZBOX ID89 Plus powered by an Intel 3rd-Generation Core processor. Equipped with a high-performance 3rd-Generation Intel Core processor with multiple cores, Intel HyperThreading and Intel Virtualization technology, the ZOTAC ZBOX ID89 Plus delivers outstanding processing power that rivals larger desktop systems while sipping miniscule amounts of energy for energy-efficient computing with unchained performance.
Intel HD Graphics with Intel Clear Video HD and Intel InTru 3D technology transforms the ZOTAC ZBOX ID89 Plus into a multimedia powerhouse with hardware-accelerated HD video playback and stereoscopic 3D video output via HDMI 1.4a. Intel Quick Sync video technology enables lightning-fast video transcoding capabilities with supported software on the ZOTAC ZBOX ID89 Plus for quick conversion of various video formats for playback on portable media players, tablets and other mobile devices.
- ZOTAC ZBOX ID89 PLUS - mini PC - Core i5 3470T 2.9 GHz - 4 GB - HDD 500 GB
- Personal computer - mini PC
- Processor
- Intel Core i5 (3rd Gen) 3470T / 2.9 GHz (3.6 GHz) (Dual-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 3Gb/s - 5400 rpm
- Optical Storage
- No optical drive
- Card Reader
- 4 in 1
- Graphics Controller
- Intel HD Graphics 2500
- Audio Output
- Integrated
- Networking
- GigE, 802.11b/g/n
- OS Provided
- No operating system
- 18.8 cm x 5.1 cm x 18.8 cm
- Personal computer
- Product Form Factor
- Mini PC
Processor / Chipset
- CPU
- Clock Speed
- 2.9 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H61 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 5400 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
Optical Storage
- No optical drive
Card Reader
- 4 in 1 card reader
- Supported Flash Memory Cards
- MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DVI, HDMI
- HDCP Compatible
Audio Output
- Integrated
- High Definition Audio
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 2 SO-DIMM 204-pin
- 1 x DVI , 1 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 3.0 (1 front, 1 rear) , 2 x USB 2.0 , 1 x headphones , 1 x microphone , 1 x TOSLINK
- Included Accessories
- Remote control, vertical stand, wall mounting kit, USB IR receiver, 2x wireless aerials
- Cables Included
- DVI-VGA adapter
- VESA Mounting Interface
- Power adapter
Operating System / Software
- OS Provided
- 18.8 cm
- 5.1 cm
- 18.8 cm
