(Jan.2010 - Web) - "I have to admit to being impressed with this bit of kit and would have no hesitation in recommending it"
(Issue 183 - Jan.2010) - "File-transfer speed tops out at 40Mbps - which is good - and works well over 3G"
Mobile Broadband - Anywhere, Anytime Internet Access
Mobile broadband allows users to access the Internet anywhere, anytime without having to depend on Wi-Fi hotspots in coffee shops, airports, other public areas or the expensive tariff rates of hotel Internet service providers
Zoom 3G Travel Router - What it does:
Zoom's portable 3G Travel Router creates a Wi-Fi Network when connected to your 3G USB modem; This allows you to share your mobile broadband Internet access between multiple Wi-Fi devices or people...
Wireless Internet from your Mobile Broadband USB Modem
This impressive little device allows the user to create their own Wi-Fi hotspot absolutely anywhere using their 3G mobile broadband USB modem...
Wi-Fi Anywhere, Anytime!
With the Zoom 4506 3G Travel Router, your computers, iPad Wi-Fi, mobile phones, games consoles, iPods or MP3/4 players, in fact ANY Wi-Fi enabled device can share your 3G Internet connection through high-speed Wireless-N. The Zoom 4506 3G Travel Router works anywhere you can receive a 3G signal - in a car, at home, at work, outdoors, at the airport, in a hotel, at a trade show - Anywhere!
Wi-Fi In Seconds
Simply plug your USB Modem into the Zoom 4506 3G Travel Router, and then any Wi-Fi devices you choose, can have fast, easy Internet access. Use it for just yourself, or share it with family members, friends, or business associates.
Compact Design
The 3G Router is pocket-sized to enable the user to take it anywhere. Measuring just 3.0 x 4.2 x 0.87 Inches (7.6 x 10.5 x 2.18 cm) and light at just 5 ounces (141.75g) including the battery!
Power & Flexibility
Zooms 3G wireless-N travel router works anywhere your mobile broadband modem works and what's best is that you don't even need a power outlet! The Travel Router works for up to 7* hours on its built-in rechargeable lithium-ion batteries. It also works and recharges when its small power adapter is plugged into a mains power outlet, or using the `In Car Charger' (Sold separately - Model 4511-00-00F) meaning that you also can use the car, caravan or camper van power outlet to create your own Internet network anywhere you travel!
Easy Setup (Includes Multi-Language Wizard)
A true `Plug & Play' device with Wireless available within seconds of connecting your 3G USB modem. For setting up wireless security (Which is recommended) Zoom provide multi-language setup wizard is included in the installation CD.
Hardware WPS (Wi-Fi Protected Setup) and Wireless on/off Button
The WPS button lets you activate the wireless protection. One-Click WPS button helps you setup a secure wireless network in a snap. Zoom 3G Routers features a control button on its side panel to enable the easy switching on and off of the Wi-Fi wireless connection. When you want to use only wired connection, you can simply pause the Wi-Fi option by pressing the button without making any extra settings.
Networking With The Travel Router
The Zoom 4506 3G Travel Router has Wireless-N capability, so it's not only compatible with Wireless N devices but also with b and g. The router supports all the popular wireless security modes, including WEP, WPA, WPA2, and WPS, so it's easy for you to control who has access to your Travel Router. The Zoom 4506 3G Travel Router is a small, but powerful wireless router with features like SPI firewall,VPN Pass-through, remote management, Universal Plug and Play, and other advanced router functions for up to 253 Wi-Fi connections,far higher than the Mi-Fi at just 5.
It also supports a wide range of connection approaches to your Internet Service Provider, including static IP, dynamic IP (DHCP client), PPTP, L2TP, PPPoE, and 3G.
When travelling, you can connect to the Travel Router through its wireless-N capability or through the Ethernet port using a Cat5e cable (Included).
Automatic Back Up For Fixed Internet Services
Some users may wish to use the Model 4506 Travel Router as an automatic back up to fixed services when at home or in the office. This can be done easily by simply connecting the Zoom 4506 3G Travel Router into the Ethernet port of an existing ADSL or Cable modem for an instant mobile broadband backup to your wired Internet connection. To set up the 3G fail-over go to the `basic setup' web page and follow the instructions.
Not used Mobile Broadband (3G) before?
Mobile broadband refers to the method of accessing the Internet from mobile computing devices and gadgets through the network coverage area provided by wireless service providers. Mobile broadband has redefined workforce mobility, on-demand entertainment and Internet connectivity access and convenience. Users can access the Internet at high speed by plugging wireless/Internet data cards, air cards or USB modems (USB dongle or stick) into the relevant slots of mobile PCs, PDA's and smart-phones. Mobile broadband has enhanced the computing capabilities of notebooks, laptops, netbooks and other mobile communication devices. Mobile workers, creative/entertainment industry professionals frequent travellers and entrepreneurs can use the Internet at high-speed for work, entertainment and other pursuits. They can access enterprise applications, download images, graphics-rich documents and files, stream videos, play online games, access large email attachments on the go.
- Zoom 4506 - wireless router - 802.11b/g/n (draft) - desktop
- Wireless router
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- Data Transfer Rate
- 150 Mbps
- TCP/IP, PPTP, L2TP, IPSec, PPPoE, IPoA
- Remote Management Protocol
- SNMP, HTTP
- Firewall protection, DMZ port, DHCP support, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, parental control, IP address filtering, Quality of Service (QoS), virtual server support
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
- 7.6 cm x 10.6 cm x 2.2 cm
- 139 g
- 1-year warranty
- Wireless router
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 150 Mbps
- Max Range Indoors
- 100 m
- Max Range Open Space
- 300 m
- SNMP, HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft), FCC, RoHS
- Status Indicators
- Status, link/activity
- 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 1
- Power Device
- External power adapter
- 7.6 cm
- 10.6 cm
- 2.2 cm
- 139 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
