Get the benefits and value associated with Zebra with MZ 320 economical receipt printers. Each tiny MZ printer can be a smart assistant for mobile receipt printing applications where you need quick, simple receipts on demand. Use 802.11g, Bluetooth, or IrDA to connect to a handheld or smart phone device and produce crisp, clear receipts!
These unobtrusive printers weigh 3/4 of a pound, so they can be worn comfortably for a full shift without interfering with the user's tasks. Stylish and compact, they're ideal for customer-facing applications where an industrial-looking printer just won't do. Its features and functions are intuitive and easy to operate as well. And because it's a Zebra, there's no compromise in reliability when you choose an MZ 320 entry-level printer.
Versatile barcode support
Equipped to handle a wide array of barcode formats including Aztec code, Codabar, Code 128, and QR code, the Zebra MZ 320 offers comprehensive scanning capabilities suitable for various industry needs. -
Durable design
Designed to withstand the rigors of daily use, the Zebra MZ 320 operates efficiently in a temperature range from -10°C to 50°C, ensuring reliable performance in diverse working environments. -
Efficient battery life
Powered by a 1500 mAh lithium-ion battery, this printer is built for extended use, minimizing downtime and maximizing productivity on-the-go. -
Wireless connectivity
With IrDA interface and wireless readiness, the Zebra MZ 320 offers flexible connectivity options, facilitating easy integration into existing systems and mobile operations. -
High-quality printing
Achieves a maximum resolution of 203 DPI for monochrome printing, ensuring clear and legible labels every time, with a maximum printing speed of 76 mm/s for efficient label production.
- Zebra MZ 320 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- Form Factor
- Portable
- 340 g
- Localisation
- United Kingdom
- Max Media Size
- Roll (7.6cm)
- Max Media Size (Custom)
- 76.2 mm x 813 mm
- Print Speed
- Up to 76 mm/sec - B/W
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, Bluetooth, IrDA
- RAM Installed (Max)
- 8 MB
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- Card Printer Program Language (CPPL)
- Barcodes
- Code 93, Code 39, UCC/EAN-128, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, FIM, Codablock F, GS1 DataBar-14
- Media Type
- Labels, continuous forms, receipt paper
- Networking
- Print server - Bluetooth
- Battery
- Required 1 Lithium Ion Included Qty 1
- System Requirements
- Microsoft Windows 2000, Microsoft Pocket PC, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows Mobile for Pocket PC 2002, Microsoft Windows CE .NET, Microsoft Windows Mobile for Pocket PC 2003 Second Edition
- Microsoft Certification
- Works with Windows Vista
- 10.4 cm x 5.7 cm x 13.6 cm
- Printer Type
- Label printer - direct thermal - monochrome
- Localisation
- United Kingdom
Printer
- Print Speed
- Up to 76 mm/sec - B/W - 203 dpi
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- Barcodes
RAM
- 8 MB
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (7.6cm)
- 76.2 mm x 813 mm
- Media Sizes
- Roll (7.6cm)
- Max Printing Width
- 73.7 mm
- Roll Maximum Outer Diameter
- 47.8 cm
- Roll Core Diameter
- 19 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (7.6cm)
- Networking
- Print server
- Data Link Protocol
- Bluetooth
- Connections
- 1 x USB , 1 x IrDA - IrDA
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- VCCI, C-Tick, BSMI, EN55022, NOM, IEC 60950, FCC Part 15 B, CCC, IC, MIC, RoHS
- Power Device
- Power adapter - external
- Lithium Ion
- Required Qty
- 1
- Included
- 1
- Capacity
- 1500 mAh
- OS Required
- -10 °C
- 50 °C
- 10 - 90%
- 10.4 cm
- 5.7 cm
- 13.6 cm
- 340 g
