At 2.2", the direct thermal and thermal transfer TLP 2824 bar code label printer is ideal for retail and other label applications. The TLP 2824 redefines the compact printer class. It fits into areas other printers cannot, withstanding rough handling and integrating easily into a wide range of applications. A 5" media roll capacity and clear media window optimize productivity, while a maximum print speed of 4" per second enables fast job processing.
The TLP 2824 excels in delivering printing solutions for business and professional offices, including retail point of sale, shelf labeling, product marking, healthcare specimen labeling and patient tracking, inventory and asset management, small office or home office mailing, shipping, and file folder labeling.
A powerful, ultra-compact printer
One of the smallest in its class, the easy-to-use 2824 Plus desktop printer tucks into your tightest work spaces and prints 2-inch-wide labels or receipts with best-in-class print speeds. The 2824 Plus includes Zebra setup utilities, which guides you through simple setup steps so you can get up and running quickly. It also includes an OpenACCESS design and clear media window for simple media loading and monitoring. -
Better performance, more flexibility
A robust 32-bit RISC processor increases throughput and productivity with faster formatting and first label out. For greater flexibility and enhanced performance, choose from a variety of options like convenient peeler and cutter, and 64 MB Flash memory that lets you store and use more graphics and fonts. With co-resident EPL and ZPL programming languages, the 2824 Plus works seamlessly with other Zebra printers, while serial/parallel/USB connectivity and optional 10/100 Ethernet allow easy system integration.
- Zebra TLP 2824 Plus - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 1.6 kg
- Max Media Size
- Roll (6 cm)
- Max Media Size (Custom)
- 60 mm
- Print Speed
- Up to 102 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB, serial
- RAM Installed (Max)
- 8 MB
- Flash Memory Installed (Max)
- 4 MB
- Language Simulation
- ZPL II, EPL2, EPL
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, UCC/EAN-128, Code 49, CODABLOCK, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Japanese Post, EAN-14, Code 128B, Code 128C, German Post, MSI-3, Code 128A, GS1 DataBar Omnidirectional
- Media Type
- Labels, continuous forms, perforated thermal paper, receipt paper, fanfold paper, tag stock
- Microsoft Certification
- Compatible with Windows 7
- 13.5 cm x 24.1 cm x 17.8 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 102 mm/sec - max speed - 203 dpi
- Connectivity Technology
- Wired
- Interface
- USB, serial
- 203 dpi
- ZPL II, EPL2, EPL
- Barcodes
RAM
- 8 MB
Flash Memory
- Flash Memory
- 4 MB
Media Handling
- Media Type
- Max Media Size
- Roll (6 cm)
- 60 mm
- Media Sizes
- Roll (6 cm)
- Max Printing Width
- 56 mm
- Max Printing Length
- 991 mm
- Media Thickness Range
- 0.08 mm - 0.18 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm, 38 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6 cm)
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- UL, VCCI, C-Tick, NOM, FCC, IRAM
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Software Included
- Drivers & Utilities, ZebraDesigner
- 5 °C
- 41 °C
- 10 - 90%
- 13.5 cm
- 24.1 cm
- 17.8 cm
- 1.6 kg
Ink (2)
Zebra Z-Select 2000D 57x32mm | In Stock | £105.51 |
Zebra Z-Select 2000D Permanent Adhesive Labels | In Stock | £109.37 |
Other bundles (1)
Zebra Z-Perform 1000D - 880191-038D Economy direct thermal paper l | In Stock | £141.27 |
