Y-cam IP Camera Wifi LAN White SD
Quicklinx: 6MD0WS00 Mfr#: YCW003
  • microSD Card
Due to the unique way the Y-cam has been designed, you no longer have to be "tech-savvy" to install and use IP video cameras. The user-friendly installation procedure and intuitive web-based interface allows you to easily connect to your camera whenever and from wherever you wish.
The Y-cam produces video at a maximum frame rate of 30fps displayed at up to 640 x 480 resolution, therefore allowing clear and smooth images to be viewed. The frame rate automatically adjusts to the available bandwidth.
Monitor and record live video and audio from anywhereYou can view live video with sound from virtually anywhere in the world as long as you have a computer, a web browser and an Internet connection. With the simple push of a button, you can take snapshots and record video directly onto your computer's hard drive.
Using the built-in microSD card slot, the Y-cam White SD no longer needs to be connected to a network or the Internet to store streaming video or motion alerts. Use the camera anywhere, even remote locations, and store video straight to microSD card, which is then viewable in your mobile phone, or via connection to a TV or PC.
Unlike many cheaper models in the market, the Y-cam utilizes the MPEG-4 compression format. This is a valuable chipset that achieves high compression ratios, allowing smooth moving images to be streamed over lower bandwidth connections.
  • Quick and simple setup
  • High quality video with sound
  • Monitor and record live video and audio from anywhere
  • Record video or motion alerts to microSD card for local backup
  • MPEG-4 compression for reduced bandwidth and storage
  • Mobile viewing
    With support for MJPEG and 3GPP the camera provides a live view for multiple platforms, including Apple Macs, and mobile devices including the iPhone and Blackberry. The Y-cam's live stream can be viewed using any mobile phone that can play VLC-compatible streams, such as Quicktime and RealPlayer.
  • Multi-client access and password protection
    The Y-cam supports up to 16 simultaneous remote users. This allows easy and efficient video conferencing with minimum setup. Password protection also ensures no one able to access the cameras without authorization.
  • Secured wireless connectivity
    The Y-cam can connect directly to a network or the Internet, either over Wireless (802.11b/g) networking, or over 10/100 with the supplied network cable. The Y-cam utilizes encryption methods such as WEP, and even the more powerful WPA and WPA2, so you can be sure your camera will only be accessed by authorized users.
Y-cam White SD - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
8.5 cm x 3 cm x 8.5 cm
150 g
Wired, wireless
Camera
Max Resolution
640 x 480
Frame Rate (max)
30 frames per second
Optical Sensor Type
CMOS - 1/4" - 0.31 MP
Minimum Illumination
1 lux
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g
Voltage
DC 5 V
Motion sensor, auto exposure control, microSD card slot, auto gain control, auto white balance
Environmental Parameters (operating)
-15 °C - 45 °C; 20 - 95% relative humidity
Audio Support
Wired, wireless
8.5 cm
3 cm
8.5 cm
150 g
Camera
Colour - fixed
Digital Video Format
MPEG-4, MJPEG
Max Digital Video Resolution
640 x 480
1 lux
Video Capture
640 x 480 @ 30 fps
Supported Image Formats
JPEG
Still Image Capture Resolution
640 x 480, 320 x 240, 160 x 120
Image Sensor
0.31 MP CMOS 1/4"
Lens Construction
Lens Iris
F/2.0
Horizontal Field of View (degree)
53.4
Vertical Field of View (degree)
40
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Supported Memory Cards
microSD Card
Stand
Power Requirements
DC 5 V
Power adapter - external 3.75 Watt
Software Included
Drivers & Utilities
Apple MacOS X 10.4, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium III - 800 MHz - RAM 128 MB , MacOS X 10.4 - PowerPC G4 - 800 MHz - RAM 128 MB
-15 °C
45 °C
Relative Humidity (operating)
20 - 95%
