Y-cam Bullet HD (Graphite)
Quicklinx: 83PDWS00 Mfr#: YCBLHD5
The Y-cam Bullet HD delivers high definition 720p video images over your network through Wi-Fi, PoE or Ethernet connections, operating independently, without the need to be connected to a computer, in full color and infrared night vision.
If any motion is detected, the camera can instantly email you an alert with snapshot, store video to microSD, or record direct to virtually any NAS drive with NAS-Ready.
Easy to install, simple to operate, secure to use; the weatherproof Y-cam Bullet HD can be viewed remotely from any PC, Mac, smartphone or tablet, including viewing direct on iPhone or iPad with audio.
  • High definition HD 720p video
    The Y-cam Bullet HD delivers crisp high definition 720p video images. Enjoy full resolution video at 30 frames per second for a truly spectacular high-definition experience, ideal for securing areas where greater image detail is required.
  • H.264 compression and AAC audio
    The H.264 compression technology allows the Bullet HD to efficiently utilize your network, even with the highest-quality video. Compatibility with AAC audio also allows for direct connection from iPhones and iPads with full video and audio.
  • True day/night picture
    Using an infrared cut filter, the Bullet HD produces true day and night quality images around the clock
  • Professional connectors
    The Y-cam Bullet HD comes with Power over Ethernet allowing you to transmit data and power over a single cable, a digital I/O for systems integration, and 2-way audio capability (provided by a built-in microphone and audio out connector) allowing you to remotely talk to anyone at your cameras site.
  • Weatherproof
    The Bullet HD is an IP66-rated outdoor camera - its waterproof and has shielded cables to ensure smooth operation in all weathers.
  • Record direct to microSD
    Using the on-camera microSD card slot, the Y-cam Bullet HD doesn't need to be connected to a network or the internet to store streaming video or motion alerts. Use the camera anywhere, even remote locations, and store video straight to microSD card, which is then viewable in your mobile phone, via connection to a TV or PC, or view footage directly from the camera over Wi-Fi.
  • Motion detection and alarms
    If the Y-cam detects movement in its field of vision, it can automatically send an email alert notifying the owner that motion has been detected, with an attached image of the scene, or it can upload footage to an FTP server so data is securely stored off-site. Unlike conventional activity detection, the Y-cam uses vector information to detect motion, therefore achieving better reliability against false alarms.
  • Secure wireless connectivity
    Freedom to place the camera where required with built-in Wi-Fi connecting directly to the Internet. Y-cam supports WEP, WPA, and WPA2 for total connection security, as well as utilizing secure password authentication so only authorized users get access.
  • View on your mobile phone
    Y-cam offer free smartphone apps to easily view and access multiple cameras from your mobile phone. Support for H.264, MJPEG and 3GPP streams means the camera feed can be directly viewed on virtually any mobile device.
Y-cam Bullet HD YCBLHD5 - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: two-way audio capability, built-in microphone
19 cm x 7 cm
0.7 kg
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
Motion Detection
Optical Sensor Type
CMOS - 1/3" - 0.9 MP (640 x 480 x 3)
Minimum Illumination
0.5 lux
Focal Length
4.2 mm
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable
Voltage
DC 12 V / PoE
IR filter, auto exposure control, Power over Ethernet, e-mail alerts, Motion Detection Technology, microSD card slot, NAS-Ready, NVR-Ready, auto gain control, auto white balance
Environmental Parameters (operating)
-5 °C - 45 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
19 cm
7 cm
0.7 kg
Camera
Colour - Day&Night - fixed - outdoor - weatherproof
Digital Video Format
MPEG-4, MJPEG, ASF, 3GPP, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
0.5 lux
Infrared LEDs
12
Video Capture
1280 x 720 @ 30 fps
Image Sensor
0.9 MP (640 x 480 x 3) CMOS 1/3"
Lens Construction
Focal Length
4.2 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
64
Vertical Field of View (degree)
36
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RTSP, RTP, UPnP, RTCP, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand, sunshield, breakout box
1 x network cable
IP66
Power Requirements
DC 12 V / PoE
Power adapter - external 3.5 Watt
Software Included
Drivers & Utilities
Linux, Apple MacOS X 10.4, Microsoft Windows 2000/XP/Vista/7
System Requirements Details
Windows 2000/XP/Vista/7 - Pentium III - 1 GHz - RAM 256 MB , MacOS X 10.4 - PowerPC G4 - 800 MHz - RAM 128 MB
-5 °C
45 °C
Relative Humidity (operating)
