WASP WLR8950 Bi-Colour CCD Barcode Scanner
Quicklinx: 3W7QWS00 Mfr#: 633808502805
Type: Barcode scanner
Form Factor: Handheld
Max Paper Size: [N/A]
Compatibility: PC, Mac
Hurry, only 3 left in stock!
£104.19 ex VAT
£125.02 inc VAT
The Wasp WLR8900 CCD LR (long-range) barcode scanner series is easy to setup and even easier to use. The lightweight, ergonomic design makes it comfortable for daily use. The Wasp WLR8900 barcode scanner series sends data to your active application as if you typed it from your keyboard. It also provides added flexibility over other CCD scanners by being able to scan barcodes from distances of up to 12 inches away.
For fast connection, the WLR8900 can simply be plugged into a keyboard wedge via USB or PS/2. It is designed for retail, point of sale, or any repetitive application where time and accuracy are important factors in making your business succeed.
Wasp WLR 8905 CCD LR Scanner - barcode scanner
Barcode scanner - handheld - USB - decoded
United Kingdom
Scan Element Type
CCD
Scan Speed
150 scan / sec
Wired
Microsoft DOS, Apple MacOS, Microsoft Windows NT, Microsoft Windows 95/98/ME/2000/XP
1-year warranty
United Kingdom
Barcode
Interface Type
USB
Scan Element Type
CCD
Scan Speed
150 scan / sec
Max Working Distance
30.5 cm
Decode Capability
Code 93, Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
TTL Decoding
Decoded
Wired
1 x USB
Limited warranty - 1 year
3W7Q WASP WWS500i/WLR8900/WDI4500 Barcode Scanner Stand In Stock £30.19
Compatibility: PC
Compatibility: Mac
Brand: WASP
